What is this noise? (Vid)
I'm posting from my phone so I'm not sure if I will be able to embed the video but I'll try. If not please click the link.
Short version:
Installed my engine and transmission into the car with the new clutch. Its an ACT unsprung 6-puck with an HD PP after which my car made this noise.
I took everything apart and rechecked the torque on the flywheel bolts because I thought I left them loose. They ended up being fine, so I threw everything back together and it still makes this noise. I'm pretty sure the pressure plate bolts are tight as I remember torquing them down with the torque wrench.
The sound seems to be coming from the trans case itself.
As you can see at the end of the video, all I have to do to quiet it down is push the clutch back in and let it out. From that point on it remains quiet. It seems to only do it when I let the clutch out fast and only in neutral.
The only other weird thing I've noticed is the lower dust cover no longer fits: when installed, the inside of the flywheel grinds on it, so I left it off. Not sure if that's related or not.
Anyone have this problem before?
https://youtu.be/Iti6tG4vzEs
Short version:
when i rebuilt the engine, i had to use a used crank from a member here. it looked perfect, was inspected and micropolished. other than that, the pistons and rods are OEM and all else is exactly like i had it before (i had no problems then).
i did the build per the service manual. i used King or ACL thrust washers. all clearances were checked. i know the flywheel and pressure plate are installed right, etc.
it's not my first build and everything went together perfect, which is why i'm really stumped.
i'd like to think the dust cover not fitting and my noise are related so i can kill two birds with one stone LOL.
or maybe my 128k trans is just going bad
my noise definitely isn't that though. this is a heavier metal. something solid.
i'm hoping. it would mean the flywheel is too close to the block. which would mean that the crank is too far forward? but everything else works, lines up, and was put together right. i've been racking my brain trying to figure out what i could have missed.
i dunno what else to do other than pull it all back out of the car and start over. eek.
i made this post hoping someone would chime in with "oh.. this one time, i overlooked..." and i'd have my answer LOL
i've been under the car for two days. i can't figure out why there isn't enough room behind the flywheel for the dust cover. i'm stumped unless there is something off with the crank, which i seriously doubt.
