Trouble with starter; video + alternatives
Old Jan 22, 2016 | 12:05 PM
Norske Marcus's Avatar
Hi guys.
Got a built car that got a faulty ignition. (No contact to engage starter, stage 3 when turning key, stage 1 & 2 are fine)
Did not have new ignition at hand, so i installed an easy-fix startbutton.
Hooked it up to the signalpower-cord directly to the starter, via the button and to the +.
Worked fine for a couple of weeks, but now I am having problems getting the starter to crank the engine (video)
I think I've got i narrowed down to 3 options (but not sure):
Alt 1: faulty starter?
Alt 2: broken teeth on engaging flywheel?
Alt 3: i messed up the original signalcable to the starter, causing a fall in amps, making the starter "to weak" to continue crankining?
Thanks for any sencible suggestions..
Old Jan 22, 2016 | 12:17 PM
The car has been running on e85 in cold climate for 2 years, so the starter has got its share of beating. Just mentioning it. Perhaps IT is of relevance.
About -15-20 now a days, but i dont think todays weather is of any relevance.
Old Jan 22, 2016 | 05:53 PM
Ians06's Avatar
Sounds like a starter to me! Bendix sound like they are not staying engaged.
Old Jan 22, 2016 | 05:54 PM
Ians06's Avatar
Make sure you have good battery voltage also...
Old Jan 23, 2016 | 12:34 AM
Battery is charged and functioning well.
IF the voltage is crucial i can also mention that i've jused a "electric thief"-a connector that cuts into the original signal-cord. (Power-thief is connected to the startbutton, and from the button to the +)
Perhaps this connector has cut to much of the cables diameter, causing it not to get enough power.
http://www.biltema.no/no/Bil---MC/Bi...tk-2000030736/
The connector i connected to the signal cable.
If this is not a possibility (damaged signal cable) I think i support the bendix suggestion.
Old Jan 23, 2016 | 02:43 AM
FTONOOB's Avatar
Jump the hot to the signal at the starter to rule out the motor itself. If it cranks easily you attack wires back.
ru4real
Jun 27, 2016 10:14 AM
nor11384
Feb 20, 2016 05:06 PM
2002EVOBOYTME
Mar 8, 2014 02:34 AM
Routybouty
Nov 25, 2010 04:13 AM
