Max horsepower for my evo?
Old Jan 27, 2016 | 09:15 PM
Christian114's Avatar
I have an 03 evo 8 2.3 gsc stage 3 beehive valve springs,fax s2 cams 274/272 billet, forged wiseco pistons, with a stock 9 turbo I know its ridiculous to put a stock 9 turbo on a built motor but I just needed a quick cheap turbo to drive around in for the mean time.
Anyways just got back from the road race and it dynoed at 421HP and 444tq on e 85 which isn't at all that bad. So I took it for a cruise and it pulls pretty good but I want more power already and I know my car can push the hp I was just curious on turbos that can with stand up to 700 to the 800 HP range.and that would be best for car thank-you.
Old Jan 27, 2016 | 10:03 PM
Pal215's Avatar
Look into FP Reds and FP Blacks for stock frame in that power range. For the record, that 9 turbo is screaming for it's life on a 2.3 liter. You probably have no lag at all haha. Did Rick tune you ?
-pal215
Old Jan 27, 2016 | 11:17 PM
That's what I've been looking in to but doesn't the red top out at around 550 and the black at around 650 and yea I know tell me about I just cruise it I just need to get to work and back for the mean time.yeA he did.
Old Jan 28, 2016 | 06:19 AM
LetsGetThisDone's Avatar
Do you know what rods are in it? If it has regular eagle or manley hbeams, you'll want to keep the torque under 550. Since you're in cali, you need a stock appearing turbo. An MHI red will do 550-600, and a black will do around 650.
Old Jan 28, 2016 | 03:51 PM
What does it matter if I'm in Cali or anywhere else it's still a built car what does it matter about having a bigger turbo and I feel I can get more power from the black so that's more where I'm leaning towards.
Old Jan 28, 2016 | 04:56 PM
Your car won't pass smog if your turbo doesn't look stock. I didn't say what turbo to get, I said you need a stock appearing turbo. And said what the red and black make in the MHI twin scroll housing.
Old Jan 28, 2016 | 05:48 PM
And yes they are Manley h beams. Can they not take much abuse. And I'll smog it with my stock turbo then put a different one in
Old Jan 29, 2016 | 10:29 AM
You gonna change the turbo every time you smog it? Or when CHP pops the hood? Manley hbeams can only handle around 550wtq. You will not be able to max out the black on them, it will be a little torque limited. I would get an MHI red. excellent spool and response, and 550-600whp. Awesome turbo.
Old Feb 9, 2016 | 12:41 PM
Rags600whpplus's Avatar
go bigger on the turbo
Old Feb 9, 2016 | 01:24 PM
Erik@MIL.SPEC's Avatar
For Cali and Manley rods, you are going to want a Red I think. Maybe even the new HTZ Green, which is a 57# a minute turbo. Going from a 9 turbo to the Black you may not be happy. And stuff typically starts breaking when you go over 600.
When I went from my White Rabbit to the OG FP Green, there was a noticeable difference in lag. I wish I had the White Rabbit insta-spool, but I'll be good with my Red and 2.3. Full spool at around 4,000 rpms or so.
mkopp06
28
Mar 3, 2007 12:07 PM
bullet1105
23
Jul 23, 2006 09:14 PM
EVOlved in PDX
21
Jun 9, 2006 08:34 PM
rlevo
Mar 3, 2006 12:46 AM
Motoracer
Mar 26, 2004 11:45 AM
