What spark plugs to get for stock evo
Old Mar 11, 2016 | 06:39 PM
Evoguy!123's Avatar
I want to replace my spark plugs but i don't know what kind of spark plugs i want one that gives my motor more power, i am a beginner i want to learn auto motive which i am in process on that. Need answers, thank (2005 evo 8 )
Old Mar 11, 2016 | 07:00 PM
kaj's Avatar
kaj
Go with the stock plugs. Different ones won't produce more power on their own.
Personally, I prefer copper because they burn nice and hot, are reasonably priced, and are easy to change.
Old Mar 11, 2016 | 07:18 PM
LetsGetThisDone's Avatar
Stock...
Old Mar 11, 2016 | 07:31 PM
Shirozake's Avatar
My 03 owner's manual calls for Iridium NGK IGR7A-G's. They run about 50$ for 4. Yikes. I usually get NGK BPR-7ES's. They're copper and usually run about 14$ for 4. Never had a problem and more affordable. I just usually have to check and/or adjust the gap. No biggie.
Old Mar 11, 2016 | 10:43 PM
slipperychicken's Avatar
http://boostedtuning.com/index.php?r...y&path=160_163
Old Mar 12, 2016 | 06:42 AM
alleggerita's Avatar
Iridium will last longer than copper in a clean engine. Copper fires better in an engine that is older and uses a bit of oil but you need to replace more often.
Old Mar 12, 2016 | 08:49 AM
kaj's Avatar
kaj
Copper is always a better conductor and worth changing more often, IMO.
Unless, our cars need iridium for a specific reason, that is. I have a IX, so I also have no choice LOL.
I use copper, when I can (in other cars) and haven't noticed any downsides.
Cliffnotes: just go OEM if you don't want to worry about it. They last forever so, that's a bonus.
Old Mar 12, 2016 | 01:33 PM
barneyb's Avatar
I bought 4 Champions at Walmart for my 8. At the time they were 95 cents each. The car ran fine.
Old Apr 4, 2016 | 07:50 AM
Rmr298's Avatar
First no plug is going to give you more power. Now that this is out of the way you should ask yourself these:
1) Will I be keeping the car stock for a while?
2) Do I want to change the plugs every 3k, 25k, 50k?
Personally I would run stock, my second choice would be iridium.
Old Apr 21, 2016 | 10:16 AM
80203's Avatar
I would definitely recommend the NGK they work well
cudaman07
Jun 23, 2015 11:41 AM
ktk
18
Mar 27, 2009 02:43 PM
johnsevo9
34
Jun 21, 2008 09:46 AM
nikkadanny
Dec 30, 2007 07:28 PM
kikiboi
12
Jul 6, 2007 12:49 PM
