De-Pinning Evo Connectors
Old Mar 18, 2016 | 06:54 PM
EVO GOES VROOM's Avatar
I'm just having issues removing some pins from the connectors. I know its pretty straight forward, but I'm not sure if I'm prying in the right areas or what....
this is the EGR connector that i'm removing the pins on. Just wanted some advise on the correct way to take them out without wrecking the plug.
Old Mar 18, 2016 | 10:39 PM
LetsGetThisDone's Avatar
I have the tool for this and they're a pain in the dick...lol. You need a thin piece of metal about 1/8-1/16 wide to get in their and push the clip up and release the pin. It goes down into the hole that the pin isn't in.
Old Mar 18, 2016 | 10:51 PM
Teal2nnr's Avatar
Edit.
Old Mar 18, 2016 | 10:52 PM
Teal2nnr's Avatar
. Nevermind
Old Mar 19, 2016 | 10:08 AM
bwanner's Avatar
use a very small flat head to get under it and put your fingers around it so it dont go flying off
Old Mar 19, 2016 | 10:37 AM
TheBoz's Avatar
I use a paper clip that is made straight and the. I file it down flat.
There're should be a little retaining clip inside the connector above the silver pin. You need to gently lift that pin while pulling on the wire. It should slide right out.
JRally
May 10, 2016 12:26 PM
ihockey1
Jul 8, 2012 11:16 AM
555R
Aug 23, 2006 07:08 AM
