blown head gasket??
If the top radiator hose is hot, the tsat is flowing some coolant. The lower shouldn't be "cold" though. That indicates the tstat is restricting flow. Good bet that's the issue.
The thermostat housing contains two temperature sensors, one for the gauge and one for the ECU. Before doing anything I'd suggest checking if both are reading hot. You could have a gauge problem.
I order the thermostat already not that expensive, however will have him check on that while we r in there .
Look at the gage for one. Evoscan or any scanner with live data for the other. When I said don't do anything before checking both temperature sensors I meant something major. Do the thermostat but there have been instances where the gage read hot and nothing was wrong except a ground was disconnected on the engine.
.What a relief, thanks to you guys here that i followed my mine and advice here and got a second person to check my car. I am so happy i didnt had to go and take my head off without changing the simple things and i was pretty darn determine to get a second opinion . Thanks again guy for your input in my situation appreciate yall
I have a friend who used to own a Stealth 2000 with a V6 engine. Anyway the shop had diagnosed his overheating problem and said he needed both headgaskets replaced. Big bucks. I told him to try a thermostat first and that fixed it. He was one happy fellow.
javicracer
60
Aug 27, 2011 12:30 PM
dsevo
31
Oct 7, 2009 10:45 PM
EVO8LTW
49
Jun 24, 2009 06:14 PM
justboosted02
Jan 3, 2009 03:58 PM
App420
Jan 27, 2007 11:02 PM
