oem bearing thickness
Old Apr 10, 2016 | 04:16 PM
saxon's Avatar
im in the middle of getting everything around for a built block and i am now at the point i want to pick out the bearings.
i have built many honda engines and they have different color bearings that respond to different thicknesses, does mitsubishi do this and if so, has anyone measured how they each one is. this will help greatly in building the motor as i can just have everything measured and order the bearings based upon the clearances desired.
thanks!
Old Apr 11, 2016 | 05:32 AM
saxon's Avatar
i guess no one builds there own motors in here?
Old Apr 12, 2016 | 11:54 AM
BiFfMaN's Avatar
If your using OEM parts then this will give you the Standard clearances to get you started, But as for a Tell-All thread, you will have to look around the site. I had to do a bit searching myself to find all the information i needed.
Plenty of threads like this....
https://www.evolutionm.net/forums/ev...ts-o-pics.html
If your crankshaft is still within specifications then you should not have a issue. Just get a Good Dial Bore gauge and dial Calipers to check measurements.
maxroach
May 27, 2017 02:02 PM
06mr775
Jan 9, 2011 12:27 AM
jamie_v1
Apr 29, 2009 03:27 AM
forbidden color
Jan 18, 2006 07:14 PM
xstang
May 7, 2004 05:26 AM
