Getting Trans off of Engine
Old Apr 16, 2016 | 07:06 PM
EvO_essence's Avatar
I have finally gotten the engine and trans together out of the engine bay and on the ground. And to begin with i have read the commons diys on trans removal and related.
So what my question is.. I unbolted the transmission from the engine while on the ground and got it about an inch apart but no further. I saw where you had to push the TOB apart or whatever but upon doing so it did nothing and now my clutch fork is stuck towards the drivers side. What am i missing? I can not figure it out for the life of me.
Old Apr 16, 2016 | 08:15 PM
LetsGetThisDone's Avatar
You need to bolt the motor and trans back together in order to release the TOB.
Old Apr 17, 2016 | 05:55 AM
Any tips on releasing it? I thought i had it then when i tried to pull it off again nothing.
Old Apr 17, 2016 | 06:03 AM
barneyb's Avatar
When you had it cracked open all you had to do is unbolt the pressure plate.
Old Apr 17, 2016 | 06:04 AM
Is that pretty easy to bust off? I will try that if so
Old Apr 17, 2016 | 02:06 PM
barneyb's Avatar
Half a dozen 10mm bolts.
Old Apr 17, 2016 | 02:47 PM
2006IXWW's Avatar
bolt the trans back to the block..... use a pry bar or big flathead and twist it to release the bearing... here's a video on how to do it..
http://youtu.be/4-x6a_LF1J8
Old Apr 18, 2016 | 11:46 AM
I got it with out unbolting anything, i appreciate the help guys
NJ_EveOhVIII
Feb 3, 2010 01:55 AM
white8
Jun 5, 2009 10:55 AM
extremier
Apr 23, 2008 05:21 PM
TTP Engineering
17
Aug 21, 2007 03:32 PM
JF1GD2
122
Mar 5, 2005 11:21 AM
