2.3 clearances
Old Sep 16, 2016 | 03:17 PM
  #31
LetsGetThisDone's Avatar
Nevermind. I though you measuring the bores and got that out of roundness...lol. Bearings get thinner towards their edges, so that sounds right. Measuring installed bearings you only measure vertically, because, as you saw, they open up as you deviate from vertical.
Old Sep 18, 2016 | 01:02 AM
  #32
roni4g63's Avatar
Alright boys, crank mains were set at .0025" rods the same, basically everything was about to get bolted together when i gapped one of my secondary rings too much, ended up with .030 thou, which is pretty freaking big from what I think
the rest were all 20 top 25-25 bottom compression ring,
so i ordered 4 more sets, should i tighten them up a little?
Old Sep 18, 2016 | 11:00 AM
  #33
roni4g63's Avatar
By the way, i ended up using king xp series race bearings, using the standard bearings, I was able to achieve the 0.0025" on both mains and rods on my new billet crank, i guess they make the race series thinner as is,
Old Sep 19, 2016 | 08:06 AM
  #34
roni4g63's Avatar
just got off the phone with Wiesco, they said 0.018" on top ring, 0.028" on bottom ring. seems excessive, they said the larger bottom ring will help with ring flutter, thoughts and ideas?
Ron
Old Sep 19, 2016 | 09:09 AM
  #35
How much power do you plan on making? That dictates upper ring gap, and then the lower ring gap should be 4-5 thou bigger. I do most at .018 upper, and .022 lower. It's funny Wiseco would recommend those gaps, it doesn't even follow what they recommend in the instructions for file fitting their rings...
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
2006GSR
10
Jun 17, 2019 11:07 AM
maxims4g63
16
Dec 10, 2009 08:15 AM
whitemonster
Nov 1, 2009 06:28 AM
EVOclub4
Sep 27, 2007 06:55 PM
