Need Help! Noise after new oil pump
Old May 24, 2016 | 05:59 AM
1sikmr's Avatar
Whats up Evom, I need some help/advice here. I just recently put a new oil pump on my 06 evo mr. Timed everything up and all looked good. Primed the new oil pump just to be sure and once I turned on the car for the first time I am now getting a loud intermittant ticking noise followed by the oil light. I only ran the motor for about 10 seconds then heard the noise and turned it off. no check engine light just the oil light comes on when the noise occurs then goes off once the noise stops sounds like its coming from the mivec gear idk what it is take a look at the video attached. Any and all help would be greatly appreciated let me know what you think. Thanks all!!
Old May 24, 2016 | 02:24 PM
Erik@MIL.SPEC's Avatar
Could be the MIVEC gear. Ask John Bradley. He'll know.
Old May 24, 2016 | 04:14 PM
kaj's Avatar
kaj
Your oil light may just be on because you haven't had enough time to pressurize the system. I don't remember how long it took my car to build pressure from being completely empty. How frequent is the ticking? Every other stroke? Completely random?
Old May 24, 2016 | 05:39 PM
1sikmr's Avatar
Totally random, I literally only let it run for 20 seconds then shut it off.
Old May 24, 2016 | 05:43 PM
kaj's Avatar
kaj
Could be so many things. Do you have a stethoscope to narrow it down?
Old May 24, 2016 | 06:14 PM
1sikmr's Avatar
Its hard to pinpoint what it is, I definately dont think its motor related but I do think it has to do with the mivec having lack of oil pressure for only 20seconds that it ran. Im just afraid of running it in fear of doing damage. When I turn the crank manually the noise is not there
Old May 24, 2016 | 07:23 PM
kaj's Avatar
kaj
Maybe it's not getting oil?
Old May 26, 2016 | 03:55 AM
1sikmr's Avatar
Update, pulled off oil filter and lines and found that I am not getting any oil to my engine. Even after I primed the oil pump using a small drill on the pump gear and spinning it to get oil into the head. Anyone have any idea?
Old May 26, 2016 | 04:12 AM
kikiturbo's Avatar
when you primed the oil pump did you check that you got the oil or did you just spin it for a couple of sec?
how did you prime it ?
did you pack the new pump with some assembly lube or oil at least?
ticking noise is your lifters / mivec running without oil
Old May 26, 2016 | 06:28 AM
1sikmr's Avatar
Yeah I spun the oil pump gear for quite a bit and allowed oil to come up to the head out of the lifters you could see the oil spraying. Then also disconnected ignition and let the car crank about 4 times prior to starting. Case/Pump was full of lube right out of the box
Old May 26, 2016 | 06:37 AM
LetsGetThisDone's Avatar
What rpm is the engine idling at? My oil light will come on if the idle dips to 500rpms...
Old May 26, 2016 | 07:05 AM
1sikmr's Avatar
Idling normal at like 800-1000rpm
Old May 27, 2016 | 10:57 AM
1sikmr's Avatar
Anyone have ideas as to why I may not have any oil circulating through the engine? Anything that coulda been messed up when installing the oil pump which seemed pretty straight forward ?
Old May 27, 2016 | 11:17 AM
kaj's Avatar
kaj
Did you delete any balance shafts? Damage to pickup? Used new gaskets?
Just brainstorming here LOL
Old May 27, 2016 | 12:31 PM
1sikmr's Avatar
Nope didnt delete balance shafts, replaced only the gasket to the pickup didnt notice and cracks or anything. Gonna drop the pan to see if i see anything out of the ordinary in there
dueces
May 17, 2017 04:24 PM
8OhOh2
Jul 7, 2015 10:48 AM
ExousiaZion
19
Jun 15, 2011 06:29 PM
prowakeskater
May 15, 2011 09:13 AM
yellowevo82
Jan 6, 2009 02:33 PM
