Wastegate actuator arm snapped!
Old Jun 13, 2016 | 10:07 AM
fugiwara's Avatar
This is a HKS GTII 7460 turbo on my EVO 8, can I have this welded? Will other wastegate actuator fit? Please advice, thank you.
If you have this part feel free to contact me, thanks.
Old Jun 13, 2016 | 11:42 AM
CDrinkH2O's Avatar
I wouldn't try to weld the actuator rod. You have two options: 1) order a replacement actuator from HKS or 2) die cut a thread onto the broken end of the actuator arm, and get a longer turnbuckle made up to fit which maintains the same overall length.
Old Jun 15, 2016 | 08:45 AM
kidkombo's Avatar
the same thing happened to me on my tomei arms m7960....instead of the actual arm, the part that mounts to the flapper valve sheared off....what a POS. try contacting HKS usa, im sure they will be able to assist you in getting a replacement.
Old Jun 15, 2016 | 09:12 AM
LetsGetThisDone's Avatar
Jus pull the turbo off and have the rod welded together. It'll work fine.
Old Jun 16, 2016 | 10:24 AM
fugiwara's Avatar
Hey thanks for the advice, I was thinking about welding it, but some suggest not to. I think welding is strong enough.
Old Jun 16, 2016 | 11:47 AM
XSivPSI's Avatar
You'll want to make sure its welded to a length that allows you to have some preload. Don't just weld it while its attached to the flapper because it will cause it to blow open slightly and hurt spool.
evoterp
Jan 29, 2014 11:32 AM
D-VO
Sep 6, 2012 08:17 AM
hlm
Jun 16, 2010 08:10 AM
EE
11
Jun 16, 2008 08:16 PM
DSMEVO15
22
Mar 14, 2007 05:53 AM
