Which cams to choose
Old Jul 14, 2016 | 01:03 AM
karakeb's Avatar
Dear EvoM members, I would like you to help me with choosing the right cams for my setup.
Below are the mods currently on my car:
-Evo 9
-2.3L stroker
-BR HTA3586R
-upgraded springs and retainers
-stock intake manifold
-ported and polished head
-GSC S1 mivec cams
Can you please advise the best tested cam selection for this setup since I prefer faster spool and I want to use the car in autocross events, thank you.
Note: I would really appreciate it if you can provide any feedback about GSC S2 and R2 mivec cams.
Bachir
Old Jul 16, 2016 | 11:10 PM
karakeb's Avatar
Bump!!!
Old Jul 16, 2016 | 11:22 PM
Tuxevo's Avatar
There's LOTS of info on cams already posted here. Just search.
Old Jul 17, 2016 | 12:00 AM
LetsGetThisDone's Avatar
Go with the R2's, they'll make more power on the 2.3L thanks to the extra valve lift and with mivec they won't affect spool.
Old Jul 17, 2016 | 03:03 AM
karakeb's Avatar
Already done that but cams related threads are old and dont provide solid numbers or graphs so i can get a real life comparison, thanks anyways.
Old Jul 17, 2016 | 03:06 AM
karakeb's Avatar
I guess i will order those along with the springs and retainers, thanks for the advice and effort.
Old Jul 17, 2016 | 09:05 AM
mrfred went from S2's to R2's on his 2.0L and made the same power with 2psi less boost. So if he had turned the boost back up, they would probably be a 20-25whp gain.
https://www.evolutionm.net/forums/ve...c-r2-cams.html
Old Jul 17, 2016 | 10:53 AM
Bhsj13's Avatar
R2's i hear are good for strokers.
Old Jul 18, 2016 | 04:07 AM
karakeb's Avatar
Thanks for sharing, I read the article and it is really interesting what these bad boys can do even on a 2.0L..
Old Jul 18, 2016 | 04:11 AM
karakeb's Avatar
Cant wait to put these bad boys in and get the car tuned soon with meth. Do you have any before/after graph with them on a stroker?
Thank you
Old Jul 18, 2016 | 07:44 AM
Thank you
Heres a set in a 2.3L with a single scroll FP red. Which is a 61lb/min turbo. The tuner said it had more power to make if the owner wanted to go to E85. Very nice powerband.
https://www.evolutionm.net/forums/ev...croll-c16.html
Old Jul 19, 2016 | 01:11 AM
karakeb's Avatar
Very Nice results, thank you for sharing this post. I will share my dyno results once the cams are installed and the car is done, thanks again.
Bachir
Old Jul 19, 2016 | 01:44 AM
foxbat's Avatar
What a coincidence, I'm going through a very similar project & waiting for the new set of cams:
Evo 9
ATP stage3 kit, GTX3576R .82AR
2.3L Engine, ported head
I opted for the S2 cams rather than the R2s, my concern was the high lift numbers of the R2s (12.10/11.90) fearing the extra turbo lag & a choppy idle
I but I'm interested in seeing your dyno results.... good luck
Old Jul 20, 2016 | 03:46 AM
karakeb's Avatar
Evo 9
Hi Foxbat,
From what I read and researched online, the R2 cams will allow more air to flow to the engine to make use of the stroker setup we have. The lag "if any " will be minimal (200-300rpm) compared to the 25-30 whp you will gain and the wider range hp and tq u will get on all RPMs. Hopefully I will get mine this weekend and by the week after the car should be ready. Once everything is done I will share my results so that you can get an idea of what to expect.
Cheers
Old Jul 20, 2016 | 07:50 AM
Lift doesn't cause choppy idle. Overlap and, to some extent, duration are what cause a choppy idle.
