no check engine light and wont turn on why?
Old Jul 18, 2016 | 01:38 AM
Evoguy!123's Avatar
hello,
i have no check engine light on and my car doesnt turn on,it cranks but wint seem to turn on iv checked fues box every single fuse work. check fuel pump and works and park plugs, the coil plugs, battery. what can be the problem?
thank you.
Old Jul 18, 2016 | 08:29 AM
Ev0ikon's Avatar
Does it have fuel? Does it actually showing sparks?
Old Jul 18, 2016 | 12:44 PM
Evoguy!123's Avatar
yes it has gas and iv checked the spark and all 4 work
Old Jul 18, 2016 | 06:36 PM
barneyb's Avatar
An engine needs spark, fuel and air to run. Next I'd check air, in other words, compression. If that is okay then do a boost leak test which is a test for too much air.
Old Jul 20, 2016 | 08:52 AM
LetsGetThisDone's Avatar
Get a Noid light kit to check if the injectors are firing.
Old Jul 21, 2016 | 05:46 AM
wreckleford's Avatar
Jumped timing?
that_guy206
Mar 22, 2013 05:13 AM
pignosesr
11
Jan 19, 2011 02:37 PM
bumblebee04
Mar 11, 2010 08:59 AM
Ralli04Art
Dec 15, 2005 06:24 AM
rt turbo
Jun 2, 2003 10:29 PM
