4G64 block, part number
Old Aug 12, 2016 | 01:26 PM
foxbat's Avatar
I'm planning to build a 4G64 with forged internals & an E9 head. I need an empty 4G64 block, I contacted the dealership & they gave me two part numbers for the 4G64 block: MD350944 (eclipse '00-05 / galant '99-03) & a less expensive MD379012 (outlander '03).
Which one is the correct part # to be used?
Or do you know of a reputable vendor that would supply an empty 4G64 block at a good price, new or used (in good shape)?
Old Aug 14, 2016 | 04:08 PM
foxbat's Avatar
Bump!
part numbers:
MD350944
MD379012
Which one to use on an Evo with E9 mivec head?
Old Aug 22, 2016 | 07:58 AM
cerevo's Avatar
Maybe this will help you some. Looks like there were several other cars that also used the 4g64
https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Old Aug 29, 2016 | 12:29 PM
foxbat's Avatar
I'm trying to find a used 4G64, I found this engine. Did any of the 4G64 models come with a Mivec head & E-Throttle?!
Old Aug 29, 2016 | 12:46 PM
cerevo's Avatar
Good question, can you tell if it has a timing belt or chain?
Old Aug 29, 2016 | 01:10 PM
foxbat's Avatar
Not yet, I'll check it tomorrow, is should be a belt...correct?
Old Aug 29, 2016 | 01:15 PM
cerevo's Avatar
http://www.club3g.com/forum/3g-eclip...-old-4g64.html
I would think so. I dont know if the newest ones use a timing chain like the evo X or not. I think they do.
Old Aug 30, 2016 | 01:16 AM
foxbat's Avatar
Confirmed, it's a belt.
Old Sep 2, 2016 | 05:39 AM
foxbat's Avatar
This engine turned to be a 4G69 not a 4G64, would this block work? I already ordered a BC 4G64 stroker kit & new 4G63 parts for the build such as the timing belt, head gasket, oil pump.....etc
Old Sep 2, 2016 | 06:03 AM
kikiturbo's Avatar
not really as 4g69 runs same deck height as 4g63.. for 4g64 specific build that runs longer rods than 4g63 you need a g64 block..
Old May 12, 2017 | 01:51 AM
kelvinTME's Avatar
Originally Posted by foxbat
Bump!
part numbers:
MD350944
MD379012
Bump for an answer!
Old May 14, 2017 | 11:38 AM
CurseDSM's Avatar
Originally Posted by kelvinTME
Bump for an answer!
Shouldnt matter what block you use the mivec is in the head not the block.
rawkus
10
Jun 20, 2016 02:07 PM
Blitz
Oct 24, 2013 07:44 AM
djikonatx
60
Sep 13, 2013 11:08 AM
mrboost05
Mar 6, 2013 09:58 AM
bostonhatcher
26
Oct 10, 2012 08:33 AM
