knock after 2step
Old Sep 6, 2016 | 09:51 AM
tsidrift1's Avatar
knock after 2step
So here is whats going on. As I lay into the 2step, there is no light flashing, as soon as I let the clutch out and start rolling, the cel light is flashing at me for knock. It continues to flash through first gear and goes away in 2nd and never returns through the whole pass. I have contacted my tuner, who is gonna look at my log.
Its showing up to 21 counts on the log. My afrs are still rich. I have searched under the hood for things vibrating and found nothing so far. I am running an exedy triple disc, so it has plenty of chatter as usual.
Is this something to really be concerned about or is it just the sensitivity of the knock sensor need adjusting?
It hasnt done this all year till the shootout, when temps were getting a little cooler.
Old Sep 6, 2016 | 11:22 AM
4b11slayer's Avatar
Do you have external dump?
Old Sep 6, 2016 | 11:24 AM
tsidrift1's Avatar
No external dump, its all recirculated.
Old Sep 6, 2016 | 05:08 PM
CurseDSM's Avatar
If it hasn't done it till now sounds like possible knock sensor going bad. Does it do it in any other gear or just off the line into first?
Old Sep 6, 2016 | 06:35 PM
tsidrift1's Avatar
Only does it in first. I did find my knock sensor was a tad loose tonight. Ill do a launch tomorrow and see if thats all it was.....really hoping so lol
Old Sep 6, 2016 | 09:02 PM
ReidFletcher's Avatar
Knock sensor is very sensitive. Requires* to be torqued to a specific number.
Old Sep 7, 2016 | 01:39 AM
CurseDSM's Avatar
You would figure if it was a tad loose it would knock every time you shifted though. Idk tighten it up and we will see i guess.
Old Sep 7, 2016 | 09:33 AM
tsidrift1's Avatar
Yea, it doesnt show knock in any other gear. Just on the launch once I release the clutch out.
Old Sep 7, 2016 | 09:40 AM
LetsGetThisDone's Avatar
Are you running tephra V7 with launch maps?
Old Sep 7, 2016 | 10:37 AM
tsidrift1's Avatar
im running tephra v7, havnt touched the launch maps.
Old Sep 7, 2016 | 01:18 PM
Ah, I was going to say the transition from the launch maps to your regular fuel and timing tables isn't always that smooth, and can induce knock. Are you sure that launch maps aren't enabled?
Old Sep 7, 2016 | 01:43 PM
tsidrift1's Avatar
I can check when I get home. If Devin didnt touch them, I havnt touched them. I dont get involved with my tunes, as much as I would like to learn about it all, I just havnt looked into it much,
Old Sep 12, 2016 | 07:05 AM
tsidrift1's Avatar
Knock sensor was loose. Did a few test launches on Sat, all is good!
Old Sep 12, 2016 | 09:04 AM
Glad you figured it out.
Old Sep 12, 2016 | 09:32 AM
STLEVOIX's Avatar
Comin down for SCT Saturday?
