Diamond race cars billet steering rack
Old Sep 24, 2016 | 06:06 PM
Grimgrak's Avatar
Comes with their subframe for 1850 shipped but has anyone run one? It's claimed for street/track. Not sure I want to mess with the evo's already fantastic steering feel...
Old Sep 25, 2016 | 08:09 AM
alleggerita's Avatar
What for? Drag? Wouldn't touch manual steering on a 3000 pound car except when going in a straight line ....
I assume you read this: https://www.evolutionm.net/forums/ev...s-lighter.html
Old Sep 25, 2016 | 04:18 PM
Grimgrak's Avatar
Nope they said it's fine for street no complaints...
Old Sep 29, 2016 | 12:17 AM
4g63Moon's Avatar
It actually steers well and easy even though it deletes the power steering. I just installed one on a customers Evo.
Old Sep 29, 2016 | 08:29 AM
But do you want to forgo the quick steering ratio and max caster the Evo clearly thrives on .... unless your focus is on drag.
Old Oct 3, 2016 | 10:51 PM
4g63Moon's Avatar
Yeah our customer's evo is a drag set up.
Old Oct 8, 2016 | 09:54 PM
Grimgrak's Avatar
Sorry why is caster lost?
Old Oct 8, 2016 | 10:18 PM
Pal215's Avatar
They geared the rack and pinion differently to allow for much easier steering at the cost of only half a circle on the steering wheel. Very worth it if you ask me, but I don't have the $$ for something like that. For a full track car and ultimate lightness, a must have.
-pal215
Old Oct 9, 2016 | 08:11 AM
On non-power assist/manual steering will get too heavy with huge amounts of caster - caster directly effects steering effort ... making it very unpleasant to maneuver at low speeds.
And gaining 1/2 a turn at the wheel for a road racing car is pure silliness. Usually manufacturers make faster racks for road race/rally. It really affects dynamic quality of a car much more than a few pounds of weight - drag being an exception.
Part of the reason the Evo is so good is its fast steering rack. With Subaru you have to buy a special rack to get a quick steering ratio; on the Evo 6 RS there was a still a special quick rack, the ratio which later got put into general production IIRC.
Old Oct 10, 2016 | 04:22 PM
barneyb's Avatar
Caster affects steering because when you steer a car with caster you are raising and lowering the height of the front of the vehicle.
Old Oct 14, 2016 | 04:35 PM
03whitegsr's Avatar
It only increases the steering wheel angle a half turn because it also turns the front wheels less overall. The steering ratio is considerably slower. Stock is like 12.5:1 (12.5* of steering wheel angle for 1* tire angle) and if I recall, this rack takes it up to like 16:1. Total steering angle is a few degrees less.
Perfectly fine though for a car heavily biased towards drag racing.
As for how difficult it would be for corners, it's a big balance between car weight, caster, scrub, tire size, and how sticky the tires are.
EvoDan2004
66
Dec 23, 2022 05:26 AM
EvoDan2004
72
Sep 10, 2017 07:29 AM
EVOlutionary
Automotosports - Illinois
Feb 10, 2012 10:40 PM
Neal@tirerack
15
Oct 9, 2007 01:59 PM
