STM Sealed Catch Can - Intake Pipe Pictures needed
Old Oct 25, 2016 | 05:30 PM
Pal215's Avatar
Originally Posted by Balrok
I recently turned my vented STM into a sealed one with a couple fittings/welding. I used the Summit 6an check valve on the intake mani.
Very cool! Would like to see pictures of your setup if you don't mind
-pal215
Old Oct 30, 2016 | 04:04 PM
Balrok's Avatar
As requested:
Here is the can installed, you can see the top fittings where shaved off and some 6an alum bungs welded in:
The summit 1 way check valve with 6an male fittings installed:
Here you can see the 3 upper lines. The one from the top fitting on the intake manifold to the check valve, the middle (with green bits) to PCV and the lower to the front VC vent.
So pretty much according to their instructions. Intake to Check to vent1, then intake pipe to vent2. I had a line on the dipstick but it pushes too much oil to be worth it.
Old Nov 1, 2016 | 10:22 AM
Pal215's Avatar
^ Excellent work Balrok and thank you for the pictures. I have the single catch can with two inlets on the sides and a filter on top. I'm thinking if I plug the filter on top, route one side with an -an splitter to both openings on the valve cover and the other side to the intake pipe to generate vacuum it should achieve the results I need if I decide to go sealed catch can (which is better). I can also keep the side hoses where they are in valve cover and just replace the top filter with a hose to the intake pipe, i think lol.
Thanks for your help!
-pal215
Old Nov 2, 2016 | 12:04 PM
Balrok's Avatar
I wouldn't quite do that depending on where the baffle in the can is, as most are designed to separate the top and bottom ports so you wouldn't want to "suck" from an unbaffled port. Keep your VC ports on the bottom two and fix your top to use the vac sources.
Old May 9, 2017 | 05:24 AM
Terror Rising's Avatar
I finally finished up the details for final mounting of my sealed catch can. I couldn't stand the look of the normal 45° intake pipe bend and had found out that STM used to sell a double 45° pipe. In talking to them about making me an old style like that we found out they still had one pipe on the shelf. I got them to add an 1/8" NPT port for the 3-port return line and a -10AN for the intake return line for the catch can. Space got pretty tight against my new radiator fan & 3-port but everything was able to be fitted with clearance. Both check valves are located back under the throttle body area to remain clean looking in the bay.
Attached Thumbnails STM Sealed Catch Can - Intake Pipe Pictures needed-img_20170508_185039026.jpg   STM Sealed Catch Can - Intake Pipe Pictures needed-img_20170508_185420834.jpg   STM Sealed Catch Can - Intake Pipe Pictures needed-img_20170307_105252129.jpg   STM Sealed Catch Can - Intake Pipe Pictures needed-img_20170508_192704266.jpg
Old Nov 17, 2017 | 09:27 PM
dookgvr4's Avatar
So this kit comes with everything needed?
I.e. I do not have to do any welding to the valve cover? The new fittings thread in?
I understand that I have to either weld in a fitting or buy the appropriate intake as well.
Old Nov 19, 2017 | 07:36 PM
GeminiEvo's Avatar
Yes, the kit comes with everything needed for install. The fittings are pressed into the valve cover by hand.
Old Nov 19, 2017 | 07:43 PM
GeminiEvo's Avatar
I bought this kit a little over a year ago. Install was easy and straight forward. I noticed recently on the STM website that they added another check valve between the intake pipe and can. Anyone know why?
Old Feb 5, 2018 | 06:27 PM
xRoguex's Avatar
There was some idle issues without it. Which makes sense.. Air was being sucked past the IAC.
Old Mar 22, 2018 | 02:43 PM
dookgvr4's Avatar
Hope this will help with line orientation with the new style. I couldn't figure it out... thankfully Connor @ STM was able to help me out but this visual may help someone down the road
Old Mar 23, 2018 | 08:21 PM
V.8MR's Avatar
Is that line making contact with the fan blades?
Old Mar 25, 2018 | 01:51 PM
dookgvr4's Avatar
No but I moved it just to be safe
WickedRSEvo
83
Apr 3, 2026 03:08 PM
cficare68
Dec 21, 2017 08:39 AM
olo
Apr 17, 2017 09:53 PM
badev0
Feb 1, 2017 06:01 AM
roni4g63
Dec 17, 2016 08:54 PM
