86.5mm in evo 8 4g63
Old Nov 25, 2016 | 05:30 AM
manu_le_ouf's Avatar
Hi , can i put 86.5mm pistons on my 4g63? some customers said 86mm max and other 87mm....
my futursetup:
gsc r2
gtx3076r
max 30psi
manley 100mm
manley turbo tuff 150mm
wiseco hd
thank's
Old Nov 25, 2016 | 02:16 PM
LetsGetThisDone's Avatar
.040 over is the max you want to bore the 4g63, that means a final size of 86mm is the biggest you want to go. That larger bore pistons are for the 4g64.
Old Nov 25, 2016 | 02:24 PM
Ok , but wiseco sell piston for 4g63 max 87,5mm
Old Nov 26, 2016 | 10:28 PM
Aby@MIL.SPEC's Avatar
you'll be fine with 86.5mm on a 4g63 block.
abnt89
Aug 24, 2017 07:07 PM
nikg
12
Feb 18, 2014 06:10 PM
Aikido
May 2, 2012 12:31 PM
scottsee
Mar 27, 2005 07:42 AM
hatchy
Mar 26, 2003 11:01 PM
