GSC 5040 vs 5041 valve spring difference
Old Nov 27, 2016 | 12:36 AM
5k6's Avatar
5k6
What is the best set for S2s on an Evo 9? They are the same price...
Old Nov 27, 2016 | 08:13 AM
ronaldo9's Avatar
This really depends on what you plan on revving too. Per GSC's site
5040 Beehive Rev and Boost range (using an S2 profile camshaft set)
Max RPM: 8,500
Max boost: 30psi
5041 Beehive Rev and Boost range (using an S3 or R2 profile camshaft set)
Max RPM: 10,500
Max boost: 44psi
Old Nov 27, 2016 | 09:57 AM
Tuxevo's Avatar
One of the GSC spring offerings was reported to have breakage issues. I believe it was either the 5040 or the less expensive option they offer. I'd suggest either the 5041 springs or the Kiggleys.
There's a thread on here that will come up if searched that will give you the specifics on which ones were failing.
Old Nov 27, 2016 | 10:53 AM
JM Auto Racing's Avatar
Silver Sponsor
If you are interested in any of those, we have 10% off through tomorrow for all GSC products.
__________________
JM Auto Racing
www.jmautoracing.com
sales@jmautoracing.com
(855)99-Turbo
Check out our New Site! Visit our website at www.jmautosports.com!
Old Nov 27, 2016 | 11:43 AM
5k6's Avatar
5k6
Are there any disadvantages with going with the 5041s if your not reving above 8500? I read in some threads about extra cam wear? Will the stiffer springs create more valve train noise?
Why not go with the 5041s?
Old Apr 25, 2018 | 02:09 AM
2rbolag's Avatar
Valid question that went unanswered. Anyone?
Old Apr 25, 2018 | 07:07 AM
5k6's Avatar
5k6
I ended up going with the 5040s. They are working great with my S2s. I did not want the extra wear on my cams and am not planning on reving above 8500rpm.
Old Apr 25, 2018 | 10:06 AM
2006EvoIXer's Avatar
cams will unlikely wear more than rocker roller bearings or cam caps.
Old Feb 15, 2019 | 10:24 PM
turboburt1's Avatar
Am reading your setup and its so close to my evoIX. I have maxed out HKS GTII-7460R at 34psi running quality E85, dynoed 476WHP. Doing some upgrades to get it close to 500 and am stock with valve springs. Getting GSC5039.
evo4life94
Apr 7, 2018 12:42 PM
rstchris
Jan 30, 2014 09:18 PM
PrimerSdime
Oct 23, 2013 07:04 PM
yositoco
Sep 6, 2013 02:02 PM
