Broken serpentine belt & water pump pulley !
Old Jan 2, 2017 | 08:45 AM
mines5's Avatar
Hi guys,
Just had the worst day today .
Installed a new OEM serpentine belt a few days ago , all tight and good. Driven it for 100 kms , today did some pulls.. During the 3rd pull the serpentine belt broke off. When i took a closer look i was amazed to see . The water pump pulley was broken, serpentine belt was torn and idler pulley was loose , so loose that it came off with hands even though we tightened it up at the time of installation.
Can not understand how water pump pulley breaks off like that ?
Has any one experienced such a failure ?
Any advice which belt to use ? what precautions do i have to take so that this does not
happen again.
Old Jan 3, 2017 | 02:11 AM
mines5's Avatar
Bump -
Old Jan 3, 2017 | 09:43 PM
4b11slayer's Avatar
Wow.
Inspect all rotating assemblies on belt route to ensure nothing is frozen.
Old Jan 4, 2017 | 12:40 AM
german_evoVII's Avatar
Its an very common problem of the Evo 4-7 Water Pump pulleys...
They are much lighter than the Evo 8/9 ones, but are prone to split in high RPM when having a lot of miles due to the thickness of the contact area.
We do replace them during service of the Timing belt to the Evo 8 / 9 pulleys on every Evo 7 or earlier when high revving is supposed...
Also Mitsubishi figured that out and so the design were changed for 8 / 9
The crack is always starting on the small lip towards the block side as you see in your picture...
Old Jan 4, 2017 | 04:43 AM
mines5's Avatar
Originally Posted by 4b11slayer
Wow.
Hi 4b..
Yeah inspected all the pulleys , all of them are rotating .
Old Jan 4, 2017 | 04:47 AM
mines5's Avatar
german_evoVII - Thanks for the input . I replaced the gates belt with OEM one which broke because of this.
Old Jan 4, 2017 | 06:12 AM
4b11slayer's Avatar
Any belt shall work, you just had a pulley failure.
Gates or what ever is more affordable. Now if it was timing belt. Factory parts
Old Jan 4, 2017 | 06:20 AM
mines5's Avatar
Some times failures like these make you over think . Its good to have a forum where people having the same interest help each other out.
Old Jan 4, 2017 | 07:04 AM
Stock belts are an bit more durable and quiet...but expensive
The gates does do the job fine, but sometimes make a bit of noise bit when cold after you put some miles on it
boosted91t
Northeast Region
Sep 28, 2011 12:44 PM
boosted91t
Sep 17, 2011 10:42 AM
