Boreless compressor wheel
Old Jan 22, 2017 | 10:48 PM
Mostafa Arafa's Avatar
Hello everybody
this is Mostafa from Egypt i'm a turbocharger technician and I found many interesting things on this website
I have some inquiries about boreless compressor wheel
1- as I noticed it is a patent for garrett so only garrett can use this also I found that it came only in the series GTA42-55
so do you think we will see this type of compressro wheel with next new series ??
2- does anyone can help me about reparing those turbos come with compressor wheel type , some times it comes without nut on the top there is no place to put my key and unassemble it , how should I deal such situation like this ? And how to deal with the balancing of this type if I unassemble this wheel how to make sure to reassemble with same position ?
Also if anyone have a video or pictures for the repairing process of anyone of those models GTA42-55 please show me
Thank you.
Old Jan 23, 2017 | 08:57 AM
LetsGetThisDone's Avatar
Is their a nut on the turbine side?
Old Jan 24, 2017 | 07:23 AM
Yes there is
Old Jan 24, 2017 | 12:41 PM
Then you would take that nut off, and the shaft will come out with the compressor. Sound like the turbo is just built the opposite way of a normal turbo (shaft is part of the compressor wheel instead of the turbine wheel).
Old Jan 25, 2017 | 11:21 AM
The nut with the turbine wheel is just the head of the cast it's not a separated nut which you can take it off , we need to nut heads in both side which you can hold from one side and rotate from the other side I faced some models with only one side ( turbine wheel ) the other side there is no nut hold it
please see the picture you can see the wheel without any nut or a place which I can hold to take it off
https://www.google.com.eg/search?q=boreless+compressor+wheel&rlz=1CDGOYI_enE G726EG726&hl=en-US&prmd=ivmn&source=lnms&tbm=isch&sa=X&ved=0ahUKEw iUm_a-gd7RAhVrCsAKHYGuD0kQ_AUICCgB&biw=320&bih=492&dpr=2 #imgrc=8SyXvpwu2GYj2M%3A
Thank you
Old Jan 25, 2017 | 11:31 AM
Some part of it is threaded. You just have to figure how hold everything and turn it.
ALLBLACK-EVO
Feb 2, 2011 08:23 PM
EVOIXreno
Aug 6, 2009 03:01 PM
1slowlaser
20
Apr 22, 2009 09:51 PM
Evo8ftw
Mar 8, 2009 06:15 PM
MalibuJack
37
Dec 29, 2004 01:21 PM
