Gen 2 gtx3076r vs. gtx3576r help
I am in the middle of selecting a turbo. I have spent the past 4 days searching and reading try to figure which would be the better choice.
The more I have read the further I get from a decision.
the two that I am torn between are gen 2 gtx3576r .61 and gtx3076r 1.01
about the car.
evo 8
ets stock flange manifold
ams intercooler
1200cc fic
twin 455 lph e85
gs2 cams
behive valve springs
car is currently 2.0 stock short block.
but will be building the bottom and increasing displacement. Not positive which displacement but greater than 2.2.
i am not looking to break 700hp, would like the quickest spool up.
So so looking for some insight for some gtx gen 2 users.
Thanks to to all I appreciate the help.
about the car.
evo 8
ams intercooler
1200cc fic
twin 455 lph e85
gs2 cams
Search the forum.
There are some comparisons on spool and apparently you don't lose much going to the GT35 turbine. In my opinion the GT30 turbine mated to the GTX76mm compressor is a bit of a mismatch. The compressor outflows the turbine by a large margin.
I DO NOT have experience with either of these turbos.
~Jaraxle
~Jaraxle
Search the forum.
~Jaraxle
~Jaraxle
Which housing would you think with the gtx3576r to run on a 2.0? I will switch the cover once the bottom end is swapped.
What are your power goals?
I personally lean toward twin scroll setups. If you are thinking open scroll then the FPRed may be another turbo to consider. It will have similar spool to the 3076 but make power like the 3576.
I am more familiar with the first gen though so the gen2 garters may have some magic sauce which makes them spool faster and make more power then the red.
I am thinking about a EFR8374 or gen 2 3582 in twin scroll. Looking for close to 600 though.
An FPBlack w/E85 will get you there, buts its not what I would consider quick spool. If you have the $$$ a FullRace EFR kit is likely the 'best' option. If you are on a budget check out ETS turbo kits. Plenty of 6266/6466 E85 dyno charts in the 600whp range.
Here is a 600hp 7670 EFR setup. https://www.evolutionm.net/forums/ev...yno-graph.html
Wouldn't an EFR outspool the FP Red (especially now that they are single scroll)?
Oh, and no, it wouldn't. Just need a good 10.5 hot side to send to FP.
https://www.evolutionm.net/forums/ev...4-dynojet.html
I don't have to worry about the turbine wheel falling off of my FP red, thus turning my turbo into a $2500 paper weight.
