Fp Green 73htz spool time.
Old Jul 15, 2017 | 11:07 AM
  #46
Nicolas's Avatar
is it possible to post a video of how your car runs with the ss fp green?
Old Jul 17, 2017 | 04:59 AM
  #47
Justin Joy's Avatar
Fixed some boost leaks this weekend that might help it spool a little faster, but rad started leaking so couldn't take it for a drive yet.
but I also found this. Anyone ever have a fp turbo leak at the number plate
Old Jul 17, 2017 | 08:57 AM
  #48
e_kobz's Avatar
The plate isn't covering any opening.....
Old Jul 17, 2017 | 08:59 AM
  #49
e_kobz's Avatar
http://www.forcedperformance.net/mer...e=Lancer-Turbo
Look at the 71hta with the anti surge housing. They don't put a badge on them, the 71-84 is just engraved into the flat spot on the compressor housing
Old Jul 17, 2017 | 09:09 AM
  #50
Justin Joy's Avatar
that's what I don't get.
I will check again in a few days make sure it wasn't from the intake and making it look like the turbo
Old Jul 17, 2017 | 09:55 AM
  #51
XSivPSI's Avatar
Since everyone is throwing boost plots in here I'll add one...
This was from the first full pull I did after putting on the FP Red turbo. I know the power/torque graph is jacked but the boost plot is accurate. 20 psi just before 3800rpm and ~25psi @ 4k
My engine wasn't the healthiest either. Had low compression test results ~140psi IIRC and poor leakdown results.
MHI FP Red Stock engine except S1 cams, O2 housing back exhaust and a huge FMIC/piping. 3rd gear. This is also wastegate only, EBC was turned off.
Old Jul 17, 2017 | 10:08 AM
  #52
kaj's Avatar
kaj
Those rivets only go on about 1/8" at the most. Nowhere near going all the way through. There is a nice, thick chunk of casting there. You won't have a leak from that spot.
Old Jul 17, 2017 | 10:13 AM
  #53
Justin Joy's Avatar
That's what I thought. Really wasn't worried about it. Got a little soap on it by accident, saw bubbles and was like wtf.
Old Jul 17, 2017 | 10:30 AM
  #54
kaj's Avatar
kaj
Bubbles from the soap settling or like a stream from leaking air?
It would be REALLY weird to have air coming out of it.
Old Jul 17, 2017 | 10:32 AM
  #55
Justin Joy's Avatar
like air leak. Cleaned away and came back. Look to be coming from under the plate but maybe I was getting some air past the coupler on the turbo and making it look like that.
Old Jul 17, 2017 | 10:48 AM
  #56
kaj's Avatar
kaj
Definitely something going on. Radiator fan, maybe? Shouldn't be air from that coupling while the car is in vacuum.
Old Jul 17, 2017 | 10:50 AM
  #57
Justin Joy's Avatar
was doing a boost lest. Car is not running. Sd set up. I put the tester right on the intake pipe.
Old Jul 17, 2017 | 10:52 AM
  #58
kaj's Avatar
kaj
Ah. Looks like you found a leak (coupling)! Score!
Old Jul 17, 2017 | 01:11 PM
  #59
V.8MR's Avatar
How do you guys think a green would fare if all I want is about 350whp but want to make it all the way to like 8k? Figure it'll blow much cooler than a stock 8/9 turbo trying to make that power and fall off less towards redline.
Old Jul 17, 2017 | 01:29 PM
  #60
e_kobz's Avatar
71hta
