New clutch problem
Old Jul 12, 2017 | 12:12 PM
Sandroc's Avatar
New clutch problem
I have a evo 9 that just had a built motor and trans installed. Had a exedy triple disc installed as well. They got everything back together and the car runs. But with the car on the clutch will not disengage enough to go into gear. Car off it seems to work just fine and if you start it in gear with the clutch pressed in it will try to move. The lines are all new and have been bleed. The master and slave are not very old and they have even tried adjusting the clutch pedal. Anyone have any suggestions on what the problem could be?
Old Jul 12, 2017 | 12:39 PM
LetsGetThisDone's Avatar
What shop is working on your car that you have to come on the internet to ask how to fix it for them?
Anyways, likely an issue with the clutch, possibly cause by install error. Trans needs to come back off so they can a look in there.
Old Jul 12, 2017 | 12:42 PM
Jmills's Avatar
X2 on this.
The clutch pedal adjustment would have been my first thought but since you've tried that I think it would be time to ask the shop.
gen3eclipsegt
Sep 6, 2009 09:19 AM
Tim2s3
Apr 24, 2009 05:14 AM
ohthree
Jan 14, 2007 07:06 PM
Go_Lancer_Go
Lancer Tranny/Drivetrain Tech
17
Jul 23, 2005 07:09 PM
figuerda
May 7, 2005 12:37 PM
