Adjustable Cam Gears for 272 Upgrade?
Agreed, I ran them on gsc s2 and I could not get any real change in power. Only spend the money if you want to waste it. Just buy a nice set of cams gsc s2 is what I would go with.
They all need degreeing because they all have errors when reground.
Even the aftermarket cam gears have errors and the zero marks are never zero.
But if you don't spend the time measuring........you won't know.
Well the other variable is if the head or block have ever been resurfaced. I'm considering a cam upgrade and maybe trying my hand at degreeing them myself.
Here is a good resource for 4G63 cam tuning and degree procedure.
If you do the maths on the resurfacing of the head/ block it's about half a crank degree at max
In fact it's so small it's insignificant.
Most or the errors are in the aftermarket gears and in the cams.
As far as the video goes.......you don't need a degree wheel.......use the ring gear.
You don't need a solid lash adjuster , use a washer under the stock one.
Remove all the rocker arms apart from the one you're measuring.
donzilla2004
Jul 12, 2013 05:12 AM
01sporty
11
Apr 1, 2013 10:24 AM
4G63 DSM
20
Feb 10, 2013 04:59 PM
EVO Nathan
38
Dec 12, 2005 09:09 AM
