Turbo woes..
Old Aug 4, 2017 | 08:59 AM
  #31
nemsin's Avatar
Originally Posted by kaj
I have a $500-800 budget. Gonna have to go OEM, then 71HTA later.
I could help you source a used Evo 6.5 RS TME turbo from Japan. Its a great turbo and holds up well as long as you run reasonable boost levels. https://www.full-race.com/store/mhi-...-rs-tme-turbo/
Old Aug 4, 2017 | 09:17 AM
  #32
kaj's Avatar
kaj
Originally Posted by razorlab
I ran an OG FP Green for four hard years of track usage and 30psi on the streets. You are going through turbos WAYYYY too quickly.
What kind of timing are you running on track?
I will have to check my logs. I know it's nothing too crazy because I'm limited by a stock short block and six speed transmission. We made sure we kept everything conservative.
if that has the titanium/aluminum CHRA, I had that on my old HTA 71 (I'm at work now and cannot click on the link ). I really like how it spooled, but I remember the exhaust wheel being on the smaller side and limiting power. I got a really good deal on it through FP because everybody was scared of the titanium wheel LOL. The poor thing had to work really hard to make decent power levels LOL
***edit: I was able to view the link from my phone. Awesome and NOT the smaller turbine housing, but DEFINITELY out of my budget.
Old Aug 4, 2017 | 09:24 AM
  #33
RazorLab's Avatar
That's why I am asking, too little timing can cause high EGT's and kill turbos.
Old Aug 4, 2017 | 09:47 AM
  #34
kaj's Avatar
kaj
I'll have to check logs when I get home. How ironic it would be if being conservative killed the car.
Old Aug 4, 2017 | 11:25 AM
  #35
nemsin's Avatar
Used ones go for less than you would think in Japan.
Old Aug 4, 2017 | 02:00 PM
  #36
kaj's Avatar
kaj
IX turbos are $350-450ish. I can't imagine shipping a TME turbo from overseas would be near that. If it were and clean? Heck yes, I'd be interested.
Old Aug 4, 2017 | 05:57 PM
  #37
RightSaid fred's Avatar
You haven't mentioned your BOV?
The easiest way to kill a turbo is to have the spring on the BOV too tight so it doesn't vent properly.
Given enough time and going from full throttle to no throttle enough times, it'll surge and kill the bearings, ending up like your photo.
High EGTs will kill the engine before the turbo.
Old Aug 4, 2017 | 06:31 PM
  #38
kaj's Avatar
kaj
Stock DV
Old Aug 4, 2017 | 10:49 PM
  #39
kikiturbo's Avatar
I can show you melted turbo bearing heat shields and cracked manifolds and turbo housings taken off from a otherwise mechanicaly perfect engine..
I think Kaj should keep it 12.5 - 11.0 on full throttle and all will be well.. (if the turbo is not running too fast from keeping too much boost at high RPM that is..)
Old Aug 5, 2017 | 06:37 AM
  #40
kaj's Avatar
kaj
The turbo seemed to barely break a sweat @ 26psi
Old Aug 5, 2017 | 04:46 PM
  #41
Stock DV
So what pressure does a stock DV blow open at?
An earlier stock plastic DV will open at just over 1 bar boost.
like here
The later metal ones open (starts to leak) at ???? PSI.
Then the turbo over speeds when trying to run more boost pressure.
Nobody knows?
Old Aug 5, 2017 | 07:21 PM
  #42
kaj's Avatar
kaj
like here
https://www.youtube.com/edit?o=U&video_id=5SvVUq1zhCA
Nobody knows?
Slightly crushed, so not sure.
Old Aug 5, 2017 | 07:51 PM
  #43
Jaraxle's Avatar
Stock metal EVO X BOV leaks at 25-26psi which is what EVERYONE said it would. I measured it here:
Old Aug 5, 2017 | 08:43 PM
  #44
4G63_EVO's Avatar
Ive measured the stock IX DV leaking at 28psi crushed holding over 30PSI
Old Aug 5, 2017 | 10:19 PM
  #45
RazorLab's Avatar
Absolutely incorrect. Please humor us and show proof to back your statement.
Nobody worth their salt runs a plastic bov on here....
