So I got the STM fittings to do an AN oil drain line on my car. Evo IX with FP71HTA turbo. Just installed a Racefab Wet Sump Oil pan and ran into this issue trying to set up a new return line:
Oil Line Fitting 1
Oil Line Fitting 2
The fitting sits right against the compressor cover. There is no room whatsoever to thread on a -10AN fitting. I've fired an email off to STM, but wondering if anyone else had run into this?
STM says it fits, I will use a short 1/2 NPT extension and then a 1/2NPT to -10AN adapter. I'll make the extension long enough to get the -10AN fitting below the compressor housing.
Couple of choices there. 1 is to attach the drain line before you attach the compressor cover to the CHRA. Basically it stays with the CHRA at all times, not a huge deal if you're swapping it once a year.
2, is to do what I did, and cut the OEM line on the turbo side just before where it bends, and weld a 10AN bung onto that. Puts it JUST in range of being useful BUT it makes it tight in there so some patience is required upon reinstall. This also makes a pretty leakproof seal since you're using the oem fitting, and it's steel on steel (regardless of gasket)
