Bw 7670 retaining ac
Old Oct 6, 2017 | 02:05 PM
jimersees's Avatar
Hi guys,
Does anyone know who can make manifolds to suit the t4 setup and retain the ac. Looking at a BW 7670 setup.
Cheers
Old Oct 6, 2017 | 02:14 PM
Toekneeng's Avatar
My ETS T4 has no issues
Old Oct 6, 2017 | 02:52 PM
kikiturbo's Avatar
my setup works... but it is t4 TS IWG only...
Old Oct 7, 2017 | 06:49 AM
4b11slayer's Avatar
Full race top mount
Old Oct 8, 2017 | 08:34 AM
Benja258's Avatar
Originally Posted by jimersees
Hi guys,
Cheers
Same question
Old Oct 8, 2017 | 10:21 PM
jimersees's Avatar
Hi,
That setup looks soo ****.... What manifold is that and does that manifold clear the ac?
Old Oct 9, 2017 | 08:26 AM
kikiturbo's Avatar
It is a manifold I designed and built. It is a T4 TS manifold, for IWG turbos, clears the AC.
Uses 48.3x2.6 mm321 ss tubing, so has about 43mm ID which is larger than your usual small bore manifold. I chose the tubing to keep the same exhaust cross section between the head and T4 flange. Runners are of equal length and as you can see the collector is somewhat different to the norm.
It is compatible with E9 radiator (some manifolds need e6 type radiator ) and comes with a specific WG actuator mount (because I think the BW mount is not right) that provides more force on the actuator and positions the wg better with regards to the block.
Also, the front engine/gearbox mount is different for more clearence of the outlet pipe.
As you might see from the pic, the turbo is mounted quite far to the gearbox side to allow me to use a propper 3 inch exhaust elbow and not a cheater one. It will actually work with a stock gearbox mount but I like more clearence around silicone elbows, and this one sits right betweeen the radiator and front gearbox mount.
As with all kits does require a slim fan.
I have a kit on its way to the US and will see if I will make more or just a few for friends..
Old Oct 9, 2017 | 09:11 AM
nemsin's Avatar
I like the Norris Designs manifold http://www.norrisdesigns.com/proddet...d=evo%2D030519
Old Oct 9, 2017 | 09:21 AM
kikiturbo's Avatar
I am not sure it is ac compatible...
however, having a external WG makes it easier as those EFRs are shorter on the exhaust side.. Having said that, it takes a tight DP to clear the AC on the full race T4 manifold with an efr...
Old Oct 9, 2017 | 04:28 PM
nemsin's Avatar
I 'think' fitting the EWG EFR's is MUCH easier, still best to verify fitment for your goals with whatever manufacturer you go with.
mooreboost
11
Jul 5, 2005 07:16 PM
ibanez_926
Jun 5, 2005 06:41 PM
DXL007
Feb 9, 2005 10:04 PM
DXL007
Feb 9, 2005 02:06 PM
darkhorse
25
Aug 10, 2004 10:41 PM
