Installing FP SS Black; what clutch to run? (Also what numbers to expect on e85?)
Will be throwing on a ss black in the next couple of weeks but i highly doubt my current comp stage 2 clutch will hold. Was debating of either going act 6 puck sprung or exedy triple? (Really against triple as it costs almost 3 times; but worst case I will go that route) I dont mind the rougher riding from the 6 puck as it isn't driven much in traffic.
Also what do you guys think I will realistically make. Fully built 2.0L Longblock on e85 with tubular headers and stock IM. (More then enough fuel to support up to 850+whp). Hoping to break 600whp.
Thanks guys
Thanks guys
Sorry for not adding on; car def won't be a track car; not at least for a while. I just like having fun with it from time to time; In between of a weekend car and DD.
Really was trying to steer away from the Twin as I've read up of it not holding a ton of power after a while. (Planning on hitting the track next year after an upgraded tranny). Glad to hear I'll be able to break 600. I was having second thoughts of the setup.
Exedy twin is a good choice but what do u mean "after a while" clutches do need to be serviced "after a while" just select the appropriate twin with the correct clamp load/force for your needs and u should be fine.
Since I don't drive the car much; I wouldn't want to buy a twin and then upgrade to a triple. Was hoping to hear a 6 puck response but it seems I may have to just bite the bullet and go with the twin/triple.
Im on fp black too. just changed to ATS twin plate and its holds fine. refer to link below
http://www.ppi-ats.com/Clutches/Pull%20clutch.html
Nelson999
E85 / Ethanol
26
Oct 10, 2011 09:15 PM
JMB8606
Nov 8, 2006 07:26 AM
evolved16
10
Oct 15, 2006 04:41 AM
