Idle issue?
I have the same issue after I got my cams installed and tuned. I think the tuned is incorrect on my car causing this issue but I havent gotten around to fix it yet. Im fixing a few odds and ends right now, Ill probably get a retune once i get all the maintenance things out of the way.
I didn't see you mention it, but have you tried new spark plugs, properly gapped.
once you are sure there are no longer any mechanical issues, and the problem persists, then yah take it in for a retune. Gather up any mods you wanna do before hand though to try and get the most out of that tuning session. Just know that tuning cold start / warm up is very difficult to dial down in a typical tuning session because the car is only cold once a day, and how cold it is depends alot on the climate/weather so its not really straight forward. Still any good tuner should have some base lines to work from that will get you pretty close.
The spark plugs don’t have 5k miles on them. I pulled them out recently and checked and they seemed ok. Guess I should get cams then a tune. Idk if I said this but the whole problem started with it reving up to like 2k when it was cold. It’s still kinda doing that but not as bad since I cleaned the throttle body and replaced the iacv.
Also I believe you said you did boost leak tests, but specifically did you find any leaks around the throttle body shaft seals, BISS O-ring or the warm up valve O-ring of the throttle body?
haven’t checked the throttle body for leaks yet because I’m thinking I need a new one anyway. Someone completely stripped the biss screw.
Toxin
15
Mar 14, 2009 12:47 PM
tt412
Jun 8, 2005 05:54 PM
