Monoloc hates OEM Tob?
Installed new act clutch with Monoloc technology with new OEM tob,
After 100miles, it pop out!
Question:
1. Does monoloc technology not compatible with OEM Tob?
2. Can i pull back the fork (pull outside but meant pushing the TOB inside) to engage it again?
Question:
Its definitely compatible.
You either didn't have it fully seated, or the retaining ring the the monoloc sits in that's in the pressure plate broke. Happened to mine. Had to send the PP back to ACT to be repaired.
Thanks man.
I will get borescope/inspection camera and i will check the rings.
If all is good, can i just pull (push tob) in back to monoloc?
You can't see the ring unless you remove the trans and take the monoloc out of the PP.
Best bet is push the TOB back in the monoloc, and see if it comes out again. If it won't stay in, it time to drop the trans and inspect.
I hope uts the first option.
Its a PITA to do it again.
Il update everything if whatever happens.
Thanks man!
Thanks man!
FS[Northeast]: BNIB Competiton Clutch Stage 3/TOB/MONOLOC
domorex
Northeast Region
May 4, 2018 12:15 PM
kyoo
23
Oct 29, 2017 09:32 AM
FS[SouthEast]: Evo X clutch, TOB, monoloc, fork stop, SS line all brand new
MrHalfSack
Jul 21, 2017 06:42 AM
electron bom
11
Feb 16, 2017 11:24 AM
My03evo
Mar 14, 2011 01:32 AM
