Soft fuel cut under boost 2.3L evo 9 Help appreciated!
I will do this when I can. I hope to tear into the car soon. We are doing the timing belt again because I suspect the belt I have is stretched. I will post back here as soon as I can. Thanks again peeps!
UPDATE: Hey guys, sorry I took so long to update this, but we got a grip of work done on the whip.
bought all new steel braided fuel feed line kit from MAP with AN fittings and Fuelab fuel filter. While pulling out the Fullblown hangar, we noticed there was a plastic oem piece that was being used for the fuel return. This piece was restricted and so we built our own using metal fittings. Also blasted out the oem return line and made sure there was no gunk in the system anywhere. Worked great. Car runs awesome and I can now hit full boost!!
We also replaced the timing belt with a gates belt and did a basic tune. Car feels good, only at 15 psi right now. Hope to get a nice 500whp once I'm tuned. Thank you all for your input, its appreciated.
uhhhh... you replaced the siphon return piece? with what?
if it doesnt siphon correctly, you leaving alot of fuel on the right side of the tank....
= stalled on side of road with fuel gauge at 1/3 full
13laqout
13
Nov 6, 2015 05:38 AM
Evo9RS1789
Aug 3, 2013 03:28 PM
Thugline
17
Apr 26, 2010 04:42 AM
binh
10
Jun 17, 2007 07:15 PM
