Evo 8 block for evo 4
Old Jan 11, 2018 | 04:09 PM
LJ7two4's Avatar
Sorry to resurrect old questions but I needed a definitive answer...I found an evo 8 block for sale locally and wanted to know if the evo 8 block will bolt up to the evo 4 head...
plan is to buy the 8 block and build both the evo 8 block and evo 4 head...will the evo 4 trans bolt up to the evo 8 motor?
Yes, I searched these current active threads:
https://www.evolutionm.net/forums/ev...gine-swap.html
https://www.evolutionm.net/forums/ge...t-evo-4-a.html
https://www.evolutionm.net/forums/ev...sfer-case.html
https://www.evolutionm.net/forums/ev...different.html
This was the closest thing I got to an answer in another thread
Originally Posted by Yogi_B
Transmissions are interchangeable and evo4-6 and evo 7-9 transfer cases will bolt up, they have the same mounting face.
What you can't do is bolt an evo 7-9 transfer case to an evo 4-6 and vice versa due to different sub frame design.
Also some other information that may be useful to future users from other threads
Originally Posted by AndyCT9W
I have a friend who put an EVO 7 engine into his EVO 4, it was a straight forward swap. All he put in was the block and the head and just used all the other components from the EVO 4 engine. The hp gain wasn't huge but there was a bit of torque increase. His car was noticeably quicker.
I would imagine the 8 wouldn't be much different. It's still a good idea to bring across the turbo and ecu for better gains.
Originally Posted by pakevo4
any twin or twin triple plate clutch designed for a evo8 5 speed will bolt on to ur evo4.if u want to use a single plate clutch ull need a evo 8 5 speed flywheel also.stock or aftermarket is your choice.btw nice 4 i got one too.pm me if u need to ask something else.
Originally Posted by japspec4g63
will fit fine. I have an evo VIII motor in my evo V
Old Jan 12, 2018 | 07:42 AM
Mauricio Evo IV's Avatar
Yes sir. Evo 8 block fit with Evo 4 head, no problem.
Evo 4-8 its the same. Even, evo 9 block fit in evo 4-8 head make a little adjustments in the block.
Old Jan 13, 2018 | 06:08 PM
LJ7two4's Avatar
Thanks! Now I can feel comfortable buying the block!!!
Old Jan 14, 2018 | 08:17 AM
Dakota Evo's Avatar
its a big upgrade which makes 4 decent cars
4 are the worst evo made from 1 to 9 due to the block
Old Jan 14, 2018 | 04:05 PM
maxroach's Avatar
Why is it worst?
Whats the difference of Evo 4 block compare to 5 6 7 8 & 9?
Old Jan 15, 2018 | 08:01 AM
kikiturbo's Avatar
it has different type of thrust bearing.... it is single piece main and thrust bearing and it usually goes bad when dealing with uprated clutches. Later blocks had separate thrust bearings..
Stealth Ag
Mar 26, 2022 08:45 PM
GSX_TO_EVO
Nov 21, 2016 06:44 PM
Knguyen228
10
Jun 11, 2009 03:28 PM
Johnboy1065
Apr 22, 2009 03:42 AM
ralliartjapracr
Sep 27, 2004 02:18 PM
