Would unplugging o2 Sensor rather than Crank sensor Skew Comp test results?
Like super bad lean or just tad bit?
Yeah it was a glory run, backed it down, kind of want to run 27~ on 92
Going to e85 soon, not sure how a dual map works with a MBC though
Is that your #4 cylinder?
What was AFR on that pull?
I think it was #1 actually
Like high 11s in the upper RPMS
I ran out of octane probably
ID1000s in there with a 255
Just got 1650 FIC low z and new 450 wally
btw plugs were BEFORE the tune, I havent checked the new ones since
the photo shown is not enough info to read them.
you need to cut the threads off and read the porcelain, or at the very least look down into the plug. --> http://www.jetsrus.com/photos/photo_...g_reading2.JPG
so much terrible info on this board, its unfortunate.
why do you say that? do you even know how to read plugs?
sblvro
Nov 21, 2012 10:22 AM
2StepsAhead
Sep 20, 2007 05:52 PM
joeracer321
14
Sep 11, 2007 05:53 AM
