New built cylinder head, can you drive it to tuner?
Old Apr 26, 2018 | 08:41 PM
maxroach's Avatar
Hello team,
In the process of finishing my install of my new AMS ported
cylinder head with 1mm oversized valves, 5041 GSC springs.
Also, it is polished and ported both intake and exhaust.
Question, can i drive it to my tuner which is 40-50 miles away?
Thanks
Old Apr 26, 2018 | 10:31 PM
2006EvoIXer's Avatar
Originally Posted by maxroach
Hello team,
Thanks
are you still on the MAF or have you switched to SD? MAF will compensate some for the higher flow but you'll need to tow it if you're on SD tune. With MAF, you can try driving it there with no boost and watch your AFR. Also, if you changed your injector size, you'll need to tow.
Old Apr 26, 2018 | 10:59 PM
LetsGetThisDone's Avatar
Start it and see what AFR's do. It'll probably be close enough to cruise it to the tuner. Fuel trims have a lot of adjustment in them.
Old Apr 27, 2018 | 07:56 AM
maxroach's Avatar
MAF still.
well see when i start it and see how afr goes.
thanks guys
Old Apr 28, 2018 | 10:07 PM
codgi's Avatar
This. Bolded being the seriously important part
rEVOlution04
19
Dec 15, 2015 08:02 PM
11secDSM
26
Oct 5, 2013 05:36 PM
RevLimiter
Aug 20, 2012 07:01 PM
Evoovasti
Apr 9, 2009 11:24 PM
