Grinding noise when rolling in neutral and in gear, car won't move.
Old May 13, 2018 | 11:24 AM
4G63_EVO's Avatar
Ok so backstory that I believe to be related, two days before incident I hit a huge semi tire on the freeway. Fast forward to incident. I'm making a 3 point turn, go into reverse, no problem, go back into first gear and car won't budge, feels like there is a wheel chock holding it back, so I give it some more gas and hear metal grinding so I back off. Put it in reverse, same issue. So I put it in neutral and push it, same thing!
Turned the car off and got my jack, lift up drivers side do a quick inspection for anything obvious, pitch black out I see nothing. I drop the car and now it moves! No grinding at all! I parked it and drove it the next morning and now there is a thumping noise that increases with speed. Parked the car and haven't had time to look at it yet. Looking for ideas of what could be the issue. I'm leaning towards cv axle/wheel bearing. What do you guys think?
Old May 13, 2018 | 11:35 AM
Biggiesacks's Avatar
I wouldn't keep driving it until you figure out whats wrong. I would start by getting all 4 tires off the ground and trying to rotate them by hand. Look for any binding, noise, anything really. I would then dump the fluids from all the drivetrain parts and see what that looks like too.I would start at the transfer case, then rear diff, then transmission.
Old May 13, 2018 | 11:39 AM
4G63_EVO's Avatar
My very first thought was tcase, but would it grind in neutral? Also I'm not driving it, it's been parked
Old May 13, 2018 | 11:42 AM
yah if the wheels are spinning so is the drivetrain.
Old May 13, 2018 | 11:50 AM
4G63_EVO's Avatar
Ah true, my wishful thinking clouded my judgment.
Any ideas why jacking up the driver wheel would rid the grinding?
Old May 13, 2018 | 11:54 AM
Super speculating here, but maybe some metal was stuck in the gears and just through moving the car around and what not it made its way out of the gear set.
Old May 13, 2018 | 12:25 PM
4G63_EVO's Avatar
Could make sense.
Think the cv axle popping out is on the table?
Old May 13, 2018 | 02:50 PM
Could make sense.
That would be easy to diagnose by doing the first test i recommended.
Old May 13, 2018 | 02:52 PM
4G63_EVO's Avatar
Yup, been planning to do it just waiting for my day off
Old May 13, 2018 | 10:17 PM
barneyb's Avatar
You ran over something and two days later the car acted up? I'm not going to say impossible but ....
You were shifting gears when this happened. I wonder if you managed to get two gears selected at the same time. That would do what you describe and then could magically disappear.
Old May 13, 2018 | 10:32 PM
4G63_EVO's Avatar
Wasn't shifting at the time, was in 5th in the freeway, and why would I have the thumping now :/
Old May 14, 2018 | 10:58 AM
barneyb's Avatar
Have you checked for bent wheels?
And yes you were shifting at the time, you were doing a three-point turn. What I was suggesting was that the lockup might not be related to the incident on the highway but instead was a hiccup in the transmission.
Old May 14, 2018 | 02:31 PM
4G63_EVO's Avatar
Oh sorry my mistake, thought you were asking if I was shifting when I hit the tire.
Now I understand, I wish it was something as simple as that, but why the sudden thumping now
Old May 14, 2018 | 04:00 PM
barneyb's Avatar
What I suggested is only a guess - one possible senario of many.
Old May 15, 2018 | 01:55 PM
4G63_EVO's Avatar
Could not replicate noise by hand, had to put the car in gear while it was in the air. Noise is coming from the center according to my buddy.
https://vimeo.com/269954712
HugePwnr
Apr 27, 2014 07:52 AM
killthelights14
19
Aug 12, 2008 04:33 PM
pullup
Sep 30, 2005 04:35 PM
umiami80
14
Dec 1, 2004 07:58 PM
Stinkapuss
Jan 13, 2004 04:37 PM
