Sheepey Built manifold/ Speed Factory Ti Bolts access
Old Jun 6, 2018 | 06:57 AM
GtheSheep's Avatar
Unhappy Sheepey Built manifold/ Speed Factory Ti Bolts access
Just wondering if anyone has used the Sheepey stock replacement manifold and/ or the Speedfactory Titanium studs and had any issues with access to the top studs? Even with a decent selection of tools still struggling to get access to the top in order to torque them up, seems like a very tight fit...considering just switching them to hex nuts rather than these 12 points?
Thanks!
Old Jun 6, 2018 | 12:29 PM
randyricci1's Avatar
I had the exact same issue. Ended up just getting the stock studs/nuts black oxide coated instead
Old Jun 6, 2018 | 12:50 PM
wht95scort's Avatar
Cut the end of a old wrench so you can tighten it. Cut like I marked.
Old Jun 6, 2018 | 01:33 PM
LetsGetThisDone's Avatar
Most tubular manifolds have the same issue. I just get stainless hex nuts.
Old Jun 6, 2018 | 07:16 PM
hutch959's Avatar
same issue...
just used hex nuts.
sheepy! leave us some room brother!!!
Old Jun 7, 2018 | 10:53 AM
fimotorsports's Avatar
I have the speedfactory ti set as well, works well with oem manifold, but have seen the fitment issues with tighter clearance manifolds. I ended up picking up some shorter ti studs with the 8 point nuts from a member on here (pm me if you want his contact info)
Old Jun 12, 2018 | 02:05 PM
Pirana's Avatar
I had to use some 6 sides nuts on mine too
JdvEvoX
Jul 27, 2017 05:01 AM
tscompusa
Sep 21, 2016 08:55 PM
Grimgrak
Dec 10, 2012 12:31 AM
