Evo 9 low RPM problem, please help
Old Jun 9, 2018 | 10:36 AM
emuleiii's Avatar
Unhappy Evo 9 low RPM problem, please help
Having this RPM idle drop under 500 issue after autoshop changed idle control valve and mass air flow sensor , would it be caused by the idle control valve or mass air flow ? (both are now aftermarket) it happens from time to time after i drive the car warm enough , no AC on.
See attached video
Old Jun 9, 2018 | 11:10 AM
wht95scort's Avatar
Sometimes the ecu learns how the car used to run and now with the new IAC valve it may have changed that. Try cleaning the throttle body first and see if it helps if not adjust the biss screw with the engine running until your car idles around 750rpm. Considering the car doesn't have cams.
evox_dev
Oct 25, 2014 04:54 PM
211Ratsbud
Nov 11, 2012 01:22 PM
nlp187
Jul 8, 2012 10:32 PM
GIsnickers
11
Sep 13, 2007 04:07 PM
TrikeDOutEvo8
Dec 26, 2005 10:32 PM
