Oil pressure regulator for Ball bearing turbochargers
#46
It has finally been solved. I was desperate and since I already had it I put the 0.030 restrictor, that originally shipped with my turbo, pre OPR and have the 0.020" restrictor post OPR and it no longer smokes. Yay. this way I assume less oil will be bypassed at the OPR as well which i assume would keep more in the pan. The gauge still shows the same 2-3 psi at hot idle and 12 or so cold. I don't know if it was that or just putting more miles on it but I think its good now. I also bought the correct oil drain from STM but haven't installed it yet. Supposedly the wrong one will eventually crack because it is stressed to get the bolts to line up.
EDIT: I also put the stock catback back on at the same time so as not to **** off my new neighbors (just moved). Not sure that would have anything to do with it smoking or not...
#47
#49
If you don't have an oil temp gauge then you may be able to just go drive around normal for 15 min then check it. Oil temp should follow coolant temps for the most part under normal conditions.
I would record all the readings once you know the oil is warm.
I've got mine set at 10-12 psi at 5K with the oil at 180* FWIW.
#50
I am trying to decide where to locate the drain for the OPR. I see some of you are using the bottom inspection hole. Is there any way to get at that without taking turbo/o2 housing out?
#55
I was thinking to try just the .030 before the turbo, after the opr. Running the dbb black and she’s a pisser.
#58
- Oil Cap
- Inspection hole on front of block (fitting from STM)
- Front valve cover (fitting from STM)
- Oil dipstick
This is my return on the GTR...
#59
Inspection hole easiest IMO, but can it still be used if my block has balance shafts deleted? I’m not sure if the oil passages were blocked etc during the balance shaft delete, I guess that’s where I’m ignorant and where I’m stuck, if I (can) use inspection hole or not. Nice setup 240!
#60
