Evo 8 sputtering
Old Jul 8, 2018 | 02:35 AM
QikEvo's Avatar
Veteran: Army
Evo 8 sputtering
I was out cruising around and did a couple of pulls. Car felt good, but on the way home on the interstate the car started to sputter if I gave it any extra gas. My wideband zero’d out and the car acted like it wanted to die. I threw it into neutral and the car idled fine. If I tried to free rev it the car would want to sputter and die. Sometimes it would sputter and clear up and sputter again. I pulled over and checked all my connections but everything seemed tight. Any idea what it could be? I’m on SD btw
Old Jul 9, 2018 | 03:16 PM
FlashEvolution's Avatar
Check plugs? Possibly injector or fuel pump issue? Check codes?
Old Jul 9, 2018 | 05:02 PM
QikEvo's Avatar
Veteran: Army
Plugs are fine. I was thinking thinking it was a fuel issue, but it has only happened once. Since the incident it hasn’t done it again. I’m also on AEM V2, so I don’t have a way to check for codes unfortunately
Old Jul 9, 2018 | 08:35 PM
Sil'vr-Boi6's Avatar
Sounds like a torn or partially ripped coupler & also check your maf sensor. My aftermarket intake FILTER had a circular plate within the filter. It came unloose and found its way smacked on my maf sensor constricting flow. Go to parts store & ask for free obd check (periodically)
Old Jul 9, 2018 | 08:39 PM
QikEvo's Avatar
Veteran: Army
I have no MAFS, because I’m running speed density. And I don’t have a check engine light because I’m running a stand-alone ecu.
Old Jul 20, 2018 | 07:09 PM
QikEvo's Avatar
Veteran: Army
anyone have any other ideas? The sputtering comes and goes. It ran fine for a couple of days and then started doing it again. The car idles fine, A/F look good at idle. When i bleep the throttle the car cuts out, then comes up again. If I barely touch the throttle, it starts to sputter really bad, then when I push the throttle completely the car shuts off. I removed my fuel rail and stock FPR, to clean them and see if that was the problem. I'm currently running dual 450's on a stock FPR, and have been running it that way for several years. I'm either thinking its the regulator going bad, or maybe the TPS. I can hear the pumps kick on when I turn the switch on. Either way, I'm just wondering if there is anything else I should look at.
Old Jul 21, 2018 | 10:19 PM
Jrah2987's Avatar
Veteran: Air Force
How old is your map sensor? Could be going out.
Old Jul 22, 2018 | 12:35 AM
QikEvo's Avatar
Veteran: Army
My 4bar map sensor is fairly old. I’ll look into that as well.
I pulled my fuel rail and regulator off. Cleaned my injectors and installed a fuel pressure gauge on my rail. The injectors were really dirty, and also cleaned up my stock regulator as well. Reinstalled everything and now the car is running just fine. I installed the gauge to see if my stock fpr was going bad, but it’s holding strong. Maybe the injectors needed to be clean.
nscahall
11
Aug 29, 2010 08:10 PM
nscahall
Mid-Atlantic Region
Jun 24, 2010 01:34 PM
PPM
10
Jan 18, 2009 05:58 PM
afmafia
83
Aug 22, 2008 06:44 PM
Willie Dynamite
May 11, 2005 08:14 PM
