Weird Issue
Old Jul 10, 2018 | 07:16 PM
C0dyix's Avatar
Weird Issue
As the title says this is a really odd issue. Ive asked many knowledgeable friends as well as my tuner, Raif from RRT and everyone is dumbfounded and i have not received a solid answer as of yet.
Basicallyy issue is when i hit bumps my RPM’s stick at 2k rpms. It makes no sense i know, but over the past 5 months its only when i hit bumps that this happens and mainly on the passenger side. Im just hoping someone on here may have dealt with this that can give me a definite answer before i have to send it to Raif and spend a fortune so he can figure it out.
And if you have a smartass answer like “jUsT aVoId BuMpS bRo” just save it. I live in NY. Potholes and bumps are all we have here
Old Jul 11, 2018 | 08:13 AM
blackline's Avatar
5 Year Member
I had an issue almost like yours, when I hit a bump the car work jerk, after logging it I found the TPS reading would drop randomly. After digging and tracing we found the TPS signal wire was cut by the ecu and only hanging on by 1 or 2 copper threads.
The ECU is on the passenger side, have you check the harness and/or pins? Have you logged the car while trying to simulate the 2k stall?
I'm also from NYC, I have the evoscan and cable so if you need to use it let me know.
Old Jul 11, 2018 | 09:08 AM
Project_Broke's Avatar
But seriously, blackline has about covered it. Log TPS, and check values. Sounds wiring related, unless your throttle cable is binding up. Check the tension on it as well. If it's tight, try giving it some slack.
Old Jul 11, 2018 | 08:34 PM
C0dyix's Avatar
appreciate both of these replies. Ill check the ecu when i have time ive been so busy with work and it seems like every time i take it out it happens. I’ll definitely look into this and if i need to borrow your laptop and cable ill let you know
Old Feb 5, 2019 | 06:58 AM
C0dyix's Avatar
Bump still having this issue and need help
Old Feb 5, 2019 | 09:46 AM
blackline's Avatar
5 Year Member
Have you logged it yet?
Old Feb 5, 2019 | 10:34 AM
C0dyix's Avatar
i have to buy a laptop and evoscan
Old Feb 5, 2019 | 12:20 PM
blackline's Avatar
5 Year Member
Gotcha, What have you tried from July 2018 to now?
  1. Did you check the connection to the ECU?
  2. Did you check the connection to the TPS?
  3. Have you replaced the TPS?
  4. Are you running a stock TB?
  5. Are you running the throttle cable via stock route or did you tuck it?
  6. have you taken it to another shop to inspect(Not saying RRT isnt a great shop but sometimes a second/fresh set of eye help)
Old Feb 5, 2019 | 03:47 PM
C0dyix's Avatar
Since the summer ive checked all the wiring to the ecu and TPS and yes stock throttle body buy i have a new s90 70mm sitting at home. My brother and i are both trying to figure it out and he works at another shop (DDA tuned). I think i might just take it back to RRT and let raif check it out since i plan on running e85 rhis year anyway
turbocheese
Apr 14, 2016 04:46 PM
turbocheese
Apr 13, 2016 11:08 PM
alex the great
Jun 16, 2012 02:50 PM
JKD
Aug 29, 2009 05:20 PM
sirloin1219
Jan 22, 2006 06:18 PM
