Need help finding a fitting size!!!!
Old Aug 21, 2018 | 03:28 PM
P0411's Avatar
I’m trying to figure out what size fitting I need for the heater core line that go’s into the drivers side of the cylinder head. I think it’s a M17 but can’t seem to find a fitting that size
that will work with the heater core hose. Has anyone replaced this fitting? If yes what’s the thread size and where did you find the fitting?
Old Aug 21, 2018 | 03:47 PM
blackline's Avatar
5 Year Member
Are you referring to this fitting?
Old Aug 21, 2018 | 04:02 PM
P0411's Avatar
Yes I am.
Old Aug 21, 2018 | 06:19 PM
hutch959's Avatar
i thought that was pressed in
Old Aug 21, 2018 | 07:12 PM
blackline's Avatar
5 Year Member
It is pressed in. I had mine break during shipping and ended up drilling/tapping a new barb fitting it.
Old Aug 22, 2018 | 03:21 PM
P0411's Avatar
What size fitting did you use and where did you find it? I believe the hole size is 17.5mm
Old Aug 22, 2018 | 03:44 PM
P0411's Avatar
Old Aug 22, 2018 | 04:20 PM
LetsGetThisDone's Avatar
1/2" pipe thread is a smidge bigger than 17mm. Can drill it to size, and tap it for 1/2" NPT.
Old Aug 22, 2018 | 07:11 PM
blackline's Avatar
5 Year Member
I'm not sure of the barb fitting specs as it was cover and repaired by the shop that ported my head.
Old Aug 23, 2018 | 06:04 PM
P0411's Avatar
Actually 1/2 NPT is quite a bit bigger. NPT 1/2 is around 21mm, and 1/2 regular thread is around 8mm. I need a fitting around M17x1.25 ish.
Old Aug 24, 2018 | 03:13 AM
The DRILL BIT size is very close to the hole. Drill, tap, send it...
25.4mm (1") x .7031= 17.86mm
You're not going to find a specific fit fitting. That is a custom press for fitting mitsu designed. good luck.
