Built motor longevity
#46
Dynoet not so much. You can play with weather correction and load control, but you're not going to make a 150whp car read 650whp. Those things also show up on the dyno sheet print out (weather does anyways). Load control would more or less just be like doing the pull in a higher gear.
#50
#51
Yeah, I've doing a lot of searches and reading up on the forum, but I just can't seem to get all the right (complete) info so I thought I'd ask for personal experiences now. lol I was leaning towards either going with a Gen 2 GTX3076R or FP Black on 93 pump gas and was hoping someone had experience with both so they can share their thoughts on pros and cons along with what kind of support mods they had. lol
The newer turbos no longer bolt up and you will never pass a smog inspection.
If you are referring to the old MHI housing black, that is a viable option if you looking to keep things simpler and costs down.
There are other factors such as fuel, etc. All that info, you've probably already read, though.
stevolee (Dec 6, 2018)
#53
FP is offering MHI housings again.
