how does slave connect to fork ?
Old Dec 5, 2018 | 03:49 AM
SeenBean's Avatar
hey guys,
sorry if this is a stupid question but how does the clutch slave cylinder bolt connect to the clutch fork ?
Evo 9 with a 5 speed RS conversion.
I lost all clutch pedal and trying to diagnose whats wrong. took off the clutch slave and there's some signs of leaking from boots but looking at how it operates I don't see how it pulls on the fork as its not connected ?
my fork is hard left against the side of the transmission housing and has spring tension when you move it to the right.
so it looks like the slave should pull on the fork ?
my slave has a threaded bolt that appears to slot into a non threaded hole in the fork- ie they are not connected. What am I missing here ? (fork side is really hard too see without stripping car down further)
Old Dec 5, 2018 | 06:30 AM
Biggiesacks's Avatar
it doesn't connect it just fits in and pushes the fork. If your fork is all the way towards the engine then the throw out bearing has popped out of the pressure plate or something like that.
Old Dec 5, 2018 | 06:49 AM
SeenBean's Avatar
yeah right. bugger.
cheers for info.
Old Dec 6, 2018 | 06:24 PM
barneyb's Avatar
Threaded slave rod, what's the story there?
Old Dec 6, 2018 | 07:20 PM
SeenBean's Avatar
Well its an Evo 9 which comes with a 6 speed transmission but I had it converted to the stronger 5 speed RS which might have something to do with it.
I seem to recall that at some stage my car was switched from push to pull config all the other way around ? I cant remember as it was done a long time ago.
Old Dec 8, 2018 | 01:23 PM
barneyb's Avatar
Yeah, thanks, I'd never seen that before.
Old Dec 8, 2018 | 03:50 PM
kaj's Avatar
kaj
Slave cylinders only push, they can't pull. Did they put a bolt in there because they lost the plunger? Maybe it's leaking around it? That's probably not right, but I could be wrong.
Anyway, your TOB collar most likely came off as mentioned above which is just a sucky job. Good luck, brotha!
Old Dec 9, 2018 | 09:39 PM
barneyb's Avatar
I've seen the linkage in a pull to push conversion and I recall a different throw out arm with a joint that reversed the throw direction. The slave still worked the same way. I assume the threaded rod was for clutch adjustment.
Old Dec 10, 2018 | 02:39 AM
SeenBean's Avatar
I'm fairly sure my car had the below link applied to it when i had a competition clutch installed. that clutch died instantly and was replaced with a exedy twin which uses the normal slave setup. So I'm guessing some of the conversion parts like the rod are still installed.
http://competitionclutch.com/tech/PUB-45106-1.pdf
Old Dec 10, 2018 | 09:27 AM
kaj's Avatar
kaj
That looks about right. What a complicated setup LOL. But push > pull for sure.
