FIC 1650s
Old Jan 10, 2019 | 04:51 PM
2006EvoIXer's Avatar
Originally Posted by huzzle101
I have the FP Stainless EVO 9 Turbine Housing, well i guess i am going injector hunting... can i be originally tuned on 1000 and then retuned on 1300cc later, been down for almost 3 weeks now.
Unless you are getting a great deal for dual map tune, I suggest you bite the bullet on bigger injectors before tuning. My dual tune is about $600, so paying that twice doesn't make sense since 1650 is almost the same price as a dual tune.
And yes, you should do hi/low rewire on 450 so it can feed your injectors up top.
Old Jan 10, 2019 | 04:52 PM
1000cc will limit you to about 450whp on E85.
kindelan4g63's Avatar
Originally Posted by 2006EvoIXer
Then I suggest going a bit bigger since SS is single scroll and can flow more up top.
450 and 1650 is a good combo.
Yea I ended up buying the FIC 1650s which were more expensive then the 2150s :/ the stainless steel internals will hold up better against other fuels from what I've read.
Old Jan 10, 2019 | 05:00 PM
Your tuner will be happy he doesn't have to tune 2150 on pump gas at idle.
Old Jan 10, 2019 | 05:03 PM
I bet ya. I asked him which he wanted me to pick up and he said not the 2150s lolol
