Fly by wire (dbw) from evo x to evo 5
Old Sep 23, 2019 | 01:10 PM
  #31
ChrisO86's Avatar
Yes exactlly. From what i have read that the 4g69 and the evo x tb are the same
Old Sep 24, 2019 | 02:13 AM
  #32
goddess7's Avatar
I use aftermarket fuel rail.
https://www.amsperformance.com/produ...ors-rail.html/
I use 4G69 TB.
Old Sep 24, 2019 | 01:24 PM
  #33
Bajanhitman's Avatar
Oh thos pics are mint thanks for sharing. My fuel feed gonna be using an AN fitting a pretty big one and aftermarket lines so I think I may still have to use a spacer. I have already ordered evo 10 pedal I think I gonna order 4g69 tb and the same toyota plugs and put everything down till I get an ecu.
Old Oct 15, 2019 | 08:49 AM
  #34
Got me an evo 10 pedal waiting throttle body. Have to order a pigtail for throttle body
Old Oct 26, 2019 | 06:40 AM
  #35
goddess7's Avatar
setting up idling.
Old Nov 1, 2019 | 06:39 AM
  #36
Is there a little input lag between you squeezing throttle and tb opening?
Old Nov 1, 2019 | 07:22 AM
  #37
I got me an evo 10 pedal and a tb off a mitsu grandis
Old Nov 9, 2019 | 04:19 PM
  #38
Slowvac's Avatar
I’m looking at installing dbw also. We were able to find a ch lancer 2.4 mivec with the complete dbw setup I need (throttle body and paddle). Hopefully there isn’t many modifications (to the paddle) to make it work apart from wiring.
Old May 5, 2020 | 07:06 PM
  #39
Any progress? I just wired my evo 10 pedal about to do the throttle body and test on Emu Black.
Old May 5, 2020 | 08:04 PM
  #40
This thread has been the most helpful thread I have ever read lol on the internet thank you so much for sharing your knowledge. I just finished pinning the throttle body and pedal to spare ecu connector. So tomorrow I will be testing on my Emu black if all goes well I will just need to get a plate made to convert the pedal to work in my Evo 4.
Old May 6, 2020 | 06:29 AM
  #41
goddess7's Avatar
bajanhitman
I've been daily driving Evo7 with LinkG4 + DBW with no problems!
The output value of the throttle sensor when cold and warm was slightly different,
so there was a problem, but it was solved.
DBW + Cyclic idle
The function is switched by the I/C spray switch.
AP and TP log files.
Old May 6, 2020 | 12:51 PM
  #42
I am having world of stress. Tried the wiring provided here got nothing. Tried the one in the ecu I get a click when powered on a whine i can har if i put it next to my ear. Assuming cause its powered. But when i try to calibrate i get noting but an error saying the tb has not moved make sure it has power.
Old May 8, 2020 | 06:16 PM
  #43
Seems my tb is dead either came that way or bad wiring on my part so I have to source one
Old May 9, 2020 | 04:32 AM
  #44
ChrisO86's Avatar
Originally Posted by Tweetbix
Bit of a thread revive, following for Pedal mounting solutions on a CP (E5/E6)
I currently have an Evo x pedal but from the looks of it I may have to do some cutting to fit the pedal where the oem one is.
do you have a lhd or rhd evo 5-6?
Old May 9, 2020 | 04:59 AM
  #45
goddess7's Avatar
TrackFormura now has an adapter for EVO5,6.
but It's only RHD.
https://trackformula.co.uk/product/m...sion-no-pedal/
