Service Engine Soon light after installing MBC
Old Apr 11, 2004 | 11:22 PM
Airs's Avatar
Hey guys, I got this light yesterday while putting in my MBC - I disconnected the neg battery wire and it went away...Guessing that it always comes up each time you disconnect the mass air flow sensor?? Today I made some adjustments and had to take the air box out again and again the light came on afterwards...Is this normal or should I take it to Autozone and have them check the error?
Old Apr 12, 2004 | 01:33 AM
Hot Feces's Avatar
Make sure the MAS is plugged in all the way. If the sensor is unplugged when you start the car, it's going to throw the SES light.
If you still have the problem, take it to Autozone and have them pull the code for you.
Old Apr 12, 2004 | 08:10 AM
juyanith's Avatar
Yeah, you should check what the CEL/SES/MIL is, otherwise we're just guessing. Another possibility is that the boost control solenoid is disconnected, this will cause an error too.
Old Apr 12, 2004 | 08:44 AM
Bom's Evo's Avatar
the the boost controller solenoid gave me a cel. i just reconnected it and bolt it down somewhere over there.
Old Apr 12, 2004 | 09:30 AM
Coolguy949's Avatar
1. Make sure the MAF is plugged in.
2. Make sure there are no vac lines that are loose, especially if the car idles kind of low.
3. Make sure the stock BCS (Solenoid) is plugged in even though the vac lines arent being used.
wowzers
Jan 1, 2015 03:33 AM
Jaeger19
Oct 8, 2011 11:16 PM
Tevo9K
17
Jul 27, 2011 07:00 PM
bbyevo8u
14
Jul 4, 2010 10:37 AM
04Evo8RS
Mar 7, 2007 01:16 PM
