Evo is super laggy
Old Jun 25, 2019 | 07:04 AM
steven121's Avatar
Evo is super laggy
Just got my new motor built already put 1k miles on it and drives awesome with no issues during the break in period
noticed that at stop lights or taking off the car has no go and takes forever for it move. Running a GTX3582R turbo before the build and never had any issues
compression test are fine 140 across all cylinders except cylinder one that reads 128 but was stripped from the previous owner and had to fix it. Pistons are 9:1 compression
i did have the head ported fully, exhaust, intake, and valves
my tune is on July 7th, im ruling out that the head has to be the reason why. Does a ported head really make that much of a difference if its not tuned?
Old Jun 29, 2019 | 08:33 AM
TariqEvo's Avatar
that is a big turbo.
before the build would u be able to remember your compression figures?
have u done a boost leak test? did you change cams while building?
and yes, a ported head would need a retune.
a tune might be able to solve that.
but a built engine should definitely be less laggy if you have gone with higher compression pistons
Old Jul 3, 2019 | 02:15 PM
steven121's Avatar
Before it ran fine, but the head was never ported and thats what im thinking. It might need more fuel
but I went with a 9:1 compression instead with 85.5mm in bore size
im getting the tune done this Friday to hit 700hp was making sure it was nothing else related
Old Jul 3, 2019 | 03:22 PM
2006EvoIXer's Avatar
Are you on SD tune and do you have AFR gauge?
Old Jul 3, 2019 | 03:58 PM
steven121's Avatar
Yes it was tuned previously on SD, and no I do not have any guages in the car and was debating on it but looks like you confirmed why I should get them
Old Jul 3, 2019 | 04:27 PM
That explains your rough idle. With oversized valves and porting, you are moving more air into engine with less pressure. Your idle is probably max lean. I have a friend in same situation and his AFR reading is passed 18.0. Lol
Bhsj13's Avatar
i have no exp with SD, but i am sure i remember people saying that SD doesnt handle new changes very well after it is tuned for a certain spec.
Old Jul 3, 2019 | 04:29 PM
Be careful and stay off boost until you get tuned. You will run lean everywhere.
Old Jul 3, 2019 | 05:22 PM
LetsGetThisDone's Avatar
All of this is pointless with the car not being tuned..
A 3582 should spool around 5-5500 on a 2.0L.
Old Jul 5, 2019 | 05:13 PM
steven121's Avatar
Great, thanks a ton! So im assuming a tune will fix this or there is nothing I can do except replace the head with a stocker which I do not want to do
just dont want to ride the clutch to build pressure
Old Jul 5, 2019 | 05:14 PM
steven121's Avatar
Tuner says I can go slightly into boost during the break in period but dont get crazy lol
trust me driving 1200 miles with no boost is tough
Old Jul 5, 2019 | 05:15 PM
steven121's Avatar
Pointless? I am asking because I never had a fully ported head before and figured since the motor is built do the top end as well
Old Jul 7, 2019 | 10:20 PM
Yes, but you will quickly forget these 1200 miles once your car is tuned. Lol
Old Jul 8, 2019 | 06:41 AM
steven121's Avatar
Lmao! Well the lift broke a few days ago so we had to push the tune back on the 15th. But ill keep yall posted
