Exedy twin disk odd noise
Old Aug 23, 2019 | 08:17 AM
Justin Keith's Avatar
Yes I am very aware that all twin disk make all sorts of weird rattles and noises. But I have had this clutch in for about 5k miles. Car still drives, shifts, and gets into boost without slipping. I got a video of the noise I am talking about that I will post in here. But It sorta sounds like a door creaking open slowly when I let out the clutch and sometimes even when I push the clutch in. Let me remind you It does NOT do this every time. It took me 4 minutes of recording to get this noise to happen one time. It also seems to squeak if I pump the clutch really fast. Not sure if that it normally. Just want some options before I remove the transmission.
Old Aug 23, 2019 | 09:24 AM
LetsGetThisDone's Avatar
Sounds like the pivots in the pressure plate are just noisy. I wouldn't worry about.
Old Aug 23, 2019 | 01:02 PM
I'm going to just drive it around the house a little bit to see if it changes. Only thing that scares me is I can feel it in the pedal. If it gets worse I am going to bring it to work and take the trans out to get a look at it. I mostly drive it on the street and have never launched it with this clutch so just seems very odd to be making that kind of noise.
Swashbuckler
62
Jan 27, 2016 07:43 PM
romogst
Aug 22, 2013 06:57 AM
v8slayer07
Jun 22, 2008 07:03 PM
evovin
38
Mar 28, 2008 04:00 AM
justchil
23
Dec 26, 2006 01:11 PM
