5/6 speed gearing options
Old Sep 15, 2019 | 06:11 AM
paga's Avatar
Hi
some years ago, i found a website with some gearing configurations mixed with 5/6 speed ratios,jdm and hks gears with ratios and teeth.
Tips to get the best way for accleration and top speed for you
i only knew that recommendation from site was for a 500awhp powered evo 8.
maybe somebody can help to find this website again.
Old Sep 15, 2019 | 10:34 AM
LetsGetThisDone's Avatar
Originally Posted by paga
Hi
Do you drive the car on the street at all? How much torque does it make?
Old Sep 15, 2019 | 10:50 AM
paga's Avatar
It have 550nm bottom to mid range. Max output is 450hp at 7000rpm.
Its for german autobahn.
Old Sep 15, 2019 | 12:08 PM
Do you want the gear acceleration biased, or, do want lower rpm for high speed cruising?
Old Sep 15, 2019 | 12:34 PM
paga's Avatar
the only way for me 6speed is to change the final drive to 4.0.
But is there a possibility to swap the 4th from 5speed into the 4th of 6speed?
Old Sep 15, 2019 | 04:52 PM
Nothing from the 5spd fits in the 6spd
Old Sep 16, 2019 | 12:12 AM
Jp7's Avatar
Jp7
I have a 6 speed with the taller final drive and the stronger gear-set that came out in 2014. (shep built).
Old Sep 18, 2019 | 03:53 PM
Pal215's Avatar
The 4.0 final drive will shift your RPMs lower for a given speed. In the OEM 6 speed trans, gear 6 at 75mph is about 3200rpm for a nice cruise. If you are going to be cruising on the autobahn, the 4.0 final drive will give you even more top speed. You will lose torque, but your car will be moving fast in 6th.
oscarquinones
May 5, 2013 08:35 AM
KIDBANGA10
Automotosports - Illinois
10
Apr 27, 2006 12:26 PM
EvolutionBoy67
Oct 20, 2003 06:29 AM
